Router can ping 8.8.8.8 but vlan clients can't
Tyrasiv
We have got a setup with a Pfsense box as the firewall between LAN and WAN.
Quick example overview:
      Firewall
            l
            l
fa1----R1---fa0
    l                 l
    l  fa0/21     l fa0/21
   S1             S2
Our problem is that our VLAN clients on the L2 switches (5, 10, 20, 30 and 99) aren't able to ping the firewall (192.168.2.2)
Router: Cisco 1811
Switches: 2960
All clients can ping the router and the router can ping 8.8.8.8.
R1#show running-config
Building configuration...
Current configuration : 2208 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name cybercenter.local
no ipv6 cef
username cisco password 0 cisco
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
ip ospf 1 area 0
interface FastEthernet0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
ip ospf 1 area 0
interface FastEthernet0.99
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
ip ospf 1 area 0
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip ospf 1 area 0
interface FastEthernet1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip ospf 1 area 0
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip ospf 1 area 0
interface Async1
no ip address
encapsulation slip
router ospf 1
log-adjacency-changes
network 192.168.0.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.99.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 0.0.0.0 0.0.0.0 FastEthernet2
no ip http server
no ip http secure-server
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login local
transport input ssh
end
And we have set the the interface which goes to the router as "switchport mode trunk"
If you are not allowed to use any routing (dynamic or static routes) then what you need to do is setup NAT on your router so all the LAN subnet IPs are translated to the 192.168.2.1 IP address which the pfSense does not need a route for as it is directly connected.
Jon
10 Replies 10
Jon Marshall
Does the pfSense have routes to the LAN subnets ?
Jon
I can also add static routes to the LAN through Pfsense but I think it's supposed to be like this
I don't think those routes are right.
Firstly they have a /32 subnet mask which is incorrect and secondly if I understand your topology correctly the routes should use the LAN interface on the pfSense.
Jon
Ah! You are right. Testing it out now
Also setting them to LAN now
You are a life saviour but I just found out that we aren't allowed to use routing on the Pfsense by our teacher...
Guess I will try some workarounds on the router
Jon
Thank you!
Now we have access to the firewall from the clients and we can also ping 8.8.8.8. We just can't get proper internet access yet
Perhaps we need to fiddle with the firewall settings on Pfsense.
We have found out it's a DNS problem from our server.
My group and I will find out the issue. Thanks for you help again
Seb Rupik
Hi there,
Since you are not NATing the traffic sources from your local subnets which are routed by the 1811, you will need to configure the pfsense box with the correct static routes (or configure OSPF and establish an adjacency), something like:
ip route 192.168.5.0 255.255.255.0 192.168.2.1
ip route 192.168.10.0 255.255.255.0 192.168.2.1
ip route 192.168.20.0 255.255.255.0 192.168.2.1
ip route 192.168.30.0 255.255.255.0 192.168.2.1
ip route 192.168.99.0 255.255.255.0 192.168.2.1
cheers,
Seb.
Hi! I'm getting this error
%Invalid next hop address (it's this router)
