Nat hairpin on a 881 router
jeremy meng
Is it possible to activate nat harpin to activate nat hairpin so that internal user can access to an internal server by rdp with the WAN IP adress ?
By default the typical configuration is
int fa 4
description wan
ip addresse X.X.X.X
ip nat enable
translation nat rule:
ip nat source static tcp Y.Y.Y.Y 3389 interface FastEthernet4 3389
Where Y.Y.Y.Y is the server IP adresss
Thanks for your help
6 Replies 6
jeremy meng
No answer ?
I need really a help for this question
The NAT NVI solution you posted  will do the job with ip nat enable on both NAT interfaces and no ip redirect on both interfaces.
Alain
I think something is still missing
Here a test configuration from a cisco 887 connected on an ADSL
interface ATM0
 no ip address
 ip nat enable
 no atm ilmi-keepalive
 pvc 8/35
  cbr 150
  tx-ring-limit 2
  encapsulation aal5mux ppp dialer
  dialer pool-member 10
interface FastEthernet0
 description LAN DATA
 switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
 no ip address
interface Vlan2
 no ip redirects
 ip nat enable
 ip virtual-reassembly in
interface Dialer10
 ip address negotiated
 no ip redirects
 ip nat enable
 encapsulation ppp
 dialer pool 10
 dialer-group 10
 ppp authentication chap callin
 ppp chap hostname adslprod@ioadsl
 ppp chap password 0 adslprod
 ppp ipcp dns request
 no cdp enable
 hold-queue 224 in
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat source list nat interface Dialer10 overload
ip nat source static tcp 192.168.1.200 3389 interface Dialer10 3389
ip route 0.0.0.0 0.0.0.0 Dialer10
ip access-list standard nat
 permit 192.168.1.0 0.0.0.255
logging esm config
192.168.1.200 is the device with rdp enable on it
Can you help on what is missing ?
Looking for some help ?
No answer ?
