NAT / Hairpinning / NVI
martinnigsch
Hi all,
Despite multiple discussions on NAT / Hairpinning / NVI I don't seem to really get it. What I want to do is the following:
 * I've got a server at 192.168.1.240:80 and :443 running which I'd like to NAT to a
 static outside IP (XXX.XXX.XXX.XXX)
 * I'd like to be capable from the internal subnet 192.168.1.* to get to the above internal server by doing
curl -L https://XXX.XXX.XXX.XXX:443 and be re-routed (NATed) to 192.168.1.240
Somehow I've got something wrong -- also I'm not sure I've get up NVI NAT correctly. Any assistance would be greatly appreciated.
Please find below my configuration.
Current configuration : 3597 bytes
! Last configuration change at 22:02:56 CEST Sun Sep 18 2022 by admin
! NVRAM config last updated at 22:05:15 CEST Sun Sep 18 2022 by admin
version 15.8
service timestamps debug datetime msec localtime show-timezone year
hostname k7b
boot-start-marker
boot-end-marker
enable secret 5 **********************
no aaa new-model
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.240 192.168.1.250
ip dhcp pool base
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server yyy.yyy.yyy.yyy yyy.yyy.yyy.yyy
ip dhcp pool alien
host 192.168.1.100 255.255.255.0
client-identifier ****.****.****.**
client-name alien
ip dhcp pool nfs
host 192.168.1.101 255.255.255.0
client-name nfs
ip dhcp pool merkur
host 192.168.1.102 255.255.255.0
client-name merkur
ip domain name example.com
ip cef
no ipv6 cef
license udi pid C931-4P sn *******
username admin password 0 ********
redundancy
interface GigabitEthernet0
switchport mode trunk
no ip address
interface GigabitEthernet1
switchport mode access
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
ip dhcp client client-id ascii k7b
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Vlan10
ip address 192.168.0.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool base 192.168.1.0 192.168.200.255 netmask 255.255.0.0
ip nat inside source list 1 interface GigabitEthernet4 overload
ip nat inside source static tcp 192.168.1.240 80 XXX.XXX.XXX.XXX 80 extendable
ip nat inside source static tcp 192.168.1.240 443 XXX.XXX.XXX.XXX 443 extendable
ip nat inside source static tcp 192.168.1.100 22 XXX.XXX.XXX.XXX 2222 extendable
ip nat inside source static tcp 192.168.1.102 6443 XXX.XXX.XXX.XXX 6443 extendable
ip nat inside source static tcp 192.168.1.99 80 XXX.XXX.XXX.XXX 7777 extendable
ip nat inside source static tcp 192.168.1.101 21 XXX.XXX.XXX.XXX 8989 extendable
ip nat inside source static tcp 192.168.1.101 20 XXX.XXX.XXX.XXX 50020 extendable
ip nat inside source static tcp 192.168.1.101 21 XXX.XXX.XXX.XXX 50021 extendable
ip nat inside source static tcp 192.168.1.101 80 XXX.XXX.XXX.XXX 50080 extendable
ip nat inside source static tcp 192.168.1.101 8543 XXX.XXX.XXX.XXX 58543 extendable
ip route 192.168.5.100 255.255.255.255 192.168.1.100
ip ssh version 2
access-list 1 permit XXX.XXX.XXX.XXX
access-list 1 permit 192.168.100.100
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
ntp server 0.at.pool.ntp.org minpoll 10
end
2 Accepted Solutions
Hello
Try the following:
no access-list 1
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet4
access-list 1 deny host 192.168.1.99
access-list 1 deny host 192.168.1.100
access-list 1 deny host 192.168.1.101
access-list 1 deny host 192.168.1.240
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 dhcp
Kind Regards
Paul
Hello
NVI nat (domainless nat -  no inside/outside domains) and using this changes the what NAT works, as now two routing decisions are made
Before and after translation, which is different from the “Old” legacy nat order of operation in domain nat and thus made harpininng much easier to work upon implementation/
The default route was set to arp for every host that’s not local to site plus it required the DHCP appended so the router would obtain the next hop wan ip address
Lasty the access-list required changing so the rtr would refine from using those specific hosts to for dynamic nat, I would say if you required further dynamic allocation based on a specific host within that access-list
Kind Regards
Paul
6 Replies 6
but the core of NVI is using
ip nat enable
no more ip nat inside and ip nat outside
Hello, thanks for the reply -- I got confused with different blog posts.
I've updated my configuration to use ip nat enable and turn off ip nat inside and ip nat outside; however, I notice two things.
1) basic NAT works, but internet access behind the nat (192.168.1.xxx) is very slow for buildup -- I seem to have introduced some kind of confusion in there.
2) hairpinning doesn't work. no access possible from 192.168.1.xxx to XXX.XXX.XXX.XXX as from outside. Any idea how to fix that?
Below my updated (much simpler) configuration.
version 15.8
hostname k7b
boot-start-marker
boot-end-marker
enable secret 5 $1$2iKo$llXBSoO8.MJ653mk/gWuG.
no aaa new-model
ip dhcp pool base
dns-server 185.67.172.25 185.67.172.26
ip dhcp pool alien
client-identifier 0130.d042.e15a.1e
client-name alien
no ip cef
no ipv6 cef
license udi pid C931-4P sn PSZ23471M4K
redundancy
no ip address
no ip address
no ip address
no ip address
ip address dhcp
no ip redirects
ip nat enable
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip redirects
ip nat enable
no ip http server
ip nat source list 1 interface GigabitEthernet4 overload
ip nat source static tcp 192.168.1.240 80 XXX.XXX.XXX.XXX 80 extendable
ip nat source static tcp 192.168.1.240 443 XXX.XXX.XXX.XXX 443 extendable
ip nat source static tcp 192.168.1.100 22 XXX.XXX.XXX.XXX 2222 extendable
ip nat source static tcp 192.168.1.99 80 XXX.XXX.XXX.XXX 7777 extendable
ip nat source static tcp 192.168.1.101 21 XXX.XXX.XXX.XXX 8989 extendable
ip nat source static tcp 192.168.1.101 20 XXX.XXX.XXX.XXX 50020 extendable
ip nat source static tcp 192.168.1.101 21 XXX.XXX.XXX.XXX 50021 extendable
ip nat source static tcp 192.168.1.101 80 XXX.XXX.XXX.XXX 50080 extendable
ip nat source static tcp 192.168.1.101 8543 XXX.XXX.XXX.XXX 58543 extendable
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
Hello
Try the following:
no access-list 1
Kind Regards
Paul
Hi Paul,
Great stuff, thanks a lot! It works -- but I've got no clue really what the mistake was that I was making could you explain maybe in a few words what the (obvious? ) mistakes were that I've made?
Thanks a lot!
Martin
Here, for reference for the community, the working NAT / NVI / hairpinning solution for running a server behind a cisco router with Nat.
Current configuration : 3277 bytes
! Last configuration change at 19:14:24 CEST Mon Sep 26 2022 by admin
version 15.8
hostname k7b
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool base
dns-server 185.67.172.xx 185.67.172.xx
ip dhcp pool alien
client-name alien
ip dhcp pool nfs
client-identifier 0100.00c0.3993.ee
client-name nfs
ip dhcp pool merkur
client-identifier ffb6.220f.eb00.0200.00ab.1144.6ab2.36bf.6410.0e
client-name merkur
no ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
ip address dhcp
no ip redirects
ip nat enable
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip redirects
ip nat enable
no ip http server
ip ssh version 2
access-list 1 deny 192.168.1.99
access-list 1 deny 192.168.1.100
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
A further problem -- now I can't seem to reach internet via Giga 4 any more from e.g. 192.168.1.100.
Can I just delete the "access-list 1 deny host 192.168.1.100"? Or do I cause trouble to the NVI nat like so?
Hello
Kind Regards
Paul
