09-26-2005 04:42 PM - edited 03-03-2019 10:36 AM
If I have 2 routers A and B. Behind router A PC1 is NAT'd to 1.1.1.1 when transmitting to router B. On router B the same PC gets NAT'd to 2.2.2.2 towards router A.
When PC1 transmits to a PC behind Router B does the return traffic have 1.1.1.1 in the headers or 2.2.2.2.
I don't believe it does 2.2.2.2. To verify I would like to be able to capture the traffic coming into the router without a sniffer. I used to have a set of commands that would enable the router to capture traffic coming into the router and the interface it would go out. Similiar to the capture command on a PIX. Is anyone familiar with this command. For some reason netflow comes to mind.
09-26-2005 09:24 PM
In this case we have static NAT on both routers so the router A sends request to 2.2.2.2 with source address 1.1.1.1 and router B sends response to 1.1.1.1 from PC behind router B with source address 2.2.2.2
10-13-2005 05:14 PM
Thanks for the reply. I was able to view the traffic using debug IP with an ACL.
Your description of my senrio was correct.
