NAT-ing on a specific ASA port
hsnanua2011
Hi everyone...
Trying to configure the cisco ASA to perform NAT-ing. The scenario is such.
Currently, we have a network topology as such
The link to the outside world is a IPSEC. The Ip addresses going through the IPSec are the 172.31.xx.xx ones.
however, there is a requiment that one specific customer does not want the 172.31.xx.xx addresses to sip into the IPSec. They would like a public ip address.
My option, is to do NAtting at the port of the ASA. So, i placed another redundant GE cable from the switch to the router, as shown below.
Say, i place it in port e0/6. And assign it to vlan 3.
How can i make a NAT for this specific port (PAT)? I am seeing that ASA can only produce NAT for a collective output...
eg : #nat (inside) xx.xx.xx.xx yy.yy.yy.yy
example :#global (outside)1 10.21.67.40-10.21.67.45 netmask       255.255.255.240
1. How can i make only e0/6 to perform nat and not the rest?
from what i see, and did
#e0/0
#nat (inside) nat id access list netmask outside ...
Is this applicable?
2. Is there any way to just perform NAT on a specific destination address?
3. any other method to accomplish this?
Configuration:
interface Vlan1
nameif inside
security-level 100
ip address 10.xxx.xx.xx 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 195.xx.xx.xx 255.255.255.0
interface Vlan3
no forward interface Vlan1
nameif application
security-level 50
ip address 172.31.xx.xx 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 3
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
Help.....
RAMACHANDRA R
you can have  static nat or port redirection. if static nat in place your server can access internet directly. if port redirection in place it will respond only to the request what it will receive from outside world. pick your option and do the config accordingly.
example : with  static nat your server can access internet and fresh traffic to this server should be allowed in access list.
static (application,outside) 195.x.x.x 172.31.x.x netmask 255.255.255.255
or you can do port redirection from outside world to specific ip address or outside interface itself.
example: With this statment server will not have access to internet and you need allow redirected port in access list to have access to the same from internet.
static (application,outside) tcp 195.x.x.x 22 172.31.x.x 22 netmask 255.255.255.255
static (application,outside) tcp 195.x.x.x 80 172.31.x.x 80 netmask 255.255.255.255
static (application,outside) tcp 195.x.x.x 443 172.31.x.x 443 netmask 255.255.255.255
static (application,outside) tcp interface 172.31.x.x 443 netmask 255.255.255.255
if you know which source is sending traffic ( customer public ip address )to these servers you can have access list outside to permit the same or else you need to open for entire public.
Rgds
Rama
