Nat inside Cisco881
isdmarvie
  Bonjour a tous
Le problème de la mise a jour du Dyndns focntionne correctement a présent, mais la NAT elle ne focntionne pas
Si quelqu'un vois la raison......
Merci d'avance
interface Dialer1
ip ddns update hostname wellmess6780.dyndns.org
ip ddns update wellmess6780_dyndns
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
ppp authentication chap pap callin
ppp chap hostname
MyLogin@SKYNET
ppp chap password 7 01125F575611505C38
ppp ipcp dns request
no cdp enable
ip default-gateway 192.168.16.254
ip forward-protocol nd
no ip http server
ip http port 8088
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.16.99 80 interface Dialer1 80
ip nat inside source static tcp 192.168.16.99 21 interface Dialer1 21
ip nat inside source static tcp 192.168.16.99 1433 interface Dialer1 1433
ip nat inside source static tcp 192.168.16.99 3389 interface Dialer1 3389
ip nat inside source static tcp 192.168.16.99 3160 interface Dialer1 3160
ip nat inside source list 100 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 100 permit ip 192.168.16.0 0.0.0.255 any
no cdp run
8 Replies 8
cadet alain
what do you mean by NAT is not working properly ?
Is routing working properly ? Can you ping 8.8.8.8 from the router ? if so then when you try from a host what is the output of sh ip nat translation | i 8.8.8.8 ?
Regards.
Alain
Regards.
Alain
Hi Alain
No, I can not ping 8.8.8.8 from the router
wellmess#sh ip nat translations | i 8.8.8.8
wellmess#
wellmess#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
wellmess#
my goal is to be able to connect to remote (Internet) on my server via port 3389 and SQL Server 1433.
as http and ftp (port 21 and 80) my goal is to be able to connect to remote (Internet) on my server via port 3389 and SQL Server 1433.
ok post output of following:
-sh ip int br
-sh ip route
- sh ip cef 8.8.8.8
Regards.
Alain
see below
wellmess#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Dialer1                    unassigned      YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              unassigned      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  down                  down
Vlan1                      192.168.16.254  YES NVRAM  up                    up
wellmess#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer1
      192.168.16.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.16.0/24 is directly connected, Vlan1
L        192.168.16.254/32 is directly connected, Vlan1
wellmess#sh ip cef 8.8.8.8
0.0.0.0/0
  attached to Dialer1
wellmess#
Hi , sorry ( router as not connectet for show command )
see below ( it's more correct )
Dialer1                    91.179.101.56   YES IPCP   up                    up
NVI0                       91.179.101.56   YES unset  administratively down down
Virtual-Access2            unassigned      YES unset  up                    up
      91.0.0.0/32 is subnetted, 2 subnets
C        91.179.101.1 is directly connected, Dialer1
C        91.179.101.56 is directly connected, Dialer1
0.0.0.0/0
  attached to Dialer1
wellmess#
ok now do this:
enable
config t
logging on
logging buffered 100000 debugging
access-list 199 permit icmp any any
do debug interface dialer 1
do debug ip packet detail 199
do ping 8.8.8.8 rep 1
do sh log
and post the output
Regards.
Alain
Hi Alain
I apologize for the delay
Ok, now everything is Ok, I'm trying to ereur from the LAN, but when I'm on a machine that is on the WAN, then I can connect via port 3389 on the server. That is to say that NAT is working properly to the internal address.
Again thank you for your great support for DDNS
Thierry
Hi Thierry,
glad it is working .
Regards.
Alain
