10-21-2009 01:48 AM - edited 03-04-2019 06:27 AM
Hi All,
Does anyone know if it is possible to NAT or PAT my Inside NAT range 172.24.53.128/25 to another inside IP address 10.4.20.226 .This is needed due to routing problems for a backup / failover vpn connection.
10-21-2009 02:36 AM
yes it is possible - but not on the same device AFAIK, you would need an intermediary device that has interfaces in both IP subnets to do this.
HTH>
Log in to Community
