Showing results forĀ
Search instead forĀ
Did you mean:Ā
NAt inside to inside interface
MarcinChameleon
Hi All,
A bit of problem with NATting  - ASA 5500 ASDM 6.2.
I have 3 interfaces: ouside, inside, inside1. Outside routes to inside interface, where both interfaces are on public IPs, so no nat control.
The new inside1 interface I want to be on oriv network 10.100.10.0/24. Now I want to NAT public IP from inside interaface to priv IP on inside2.
Basically NATTing must occur between inside and inside2 - on priv IP there is web server.
Can I do somehow without nat enabling command? I just need NAT for few IPs.
TIA for any help.
Marcin
20 Replies 20
if you want the device to be available from the outside - you need to:-
1) Allow access via an access-list - as the outside is security 0 and Inside1 is security 100
2) You need to have a NAT in place - you could peform PAT on the outside - of try and use the same NAT IP as the inside so something like
static (Inside1,outside) 83.89.92.250 10.100.10.2 netmask 255.255.255.255
Does it mean I have to do enable NAT for everything? OR still I can do NAT and PAT just for chosen IPs?
you can still just do nat and pat.
Andrew, thanks for everything.
Would you be so kind and help me with this NAT and PAT config for outside interafce?
Only for just one mapping, the rest I would just replicate.
BIG TIA.
IT'S WORKING!!!
Big thanks Andrew for all your help and support!
That was the last missing config -
static (Inside1,outside) 83.89.92.250 10.100.10.2 netmask 255.255.255.255 and it worked nicely.
All the best in 2012.
Marcin.
No - glad to help.
And to you.
