NAT Issue with PBR
ahmad82pkn
Level 3
Level 3
Am i doing any logical mistake here?
I have one destination that is 150.150.150.150  and Three Sources Need to Access it.
I want my Source                 1.1.1.1 to NAT into 2.2.2.1 when it hit Destination 150.150.150.150
I want my Second Source     1.1.1.2 to NAT into 2.2.2.2 when it hit Destination 150.150.150.150
i want my Third     Source     1.1.1.3 to NAT into 2.2.2.3 when it hit Destination 150.150.150.150
Here is NAT Config with PBR
ip nat inside source static 1.1.1.1 2.2.2.1 route-map PBRMAP
ip nat inside source static 1.1.1.2 2.2.2.2 route-map PBRMAP
ip nat inside source static 1.1.1.3 2.2.2.3 route-map PBRMAP
route-map PBRMAP 10
      match ip address PBR
Extended IP access list PBR
    20 permit ip host 1.1.1.1 host 192.168.151.50
    30 permit ip host 1.1.1.2 host 192.168.151.50
    40 permit ip host 1.1.1.3 host 192.168.151.50
Soem times it works, some time it doesnt. am i doing logical mistake by calling same Route map in all three NAT statements?
Do i need to create 3 different Routemaps and ACL?
or above config is good and should be working as desired?
Harold Ritter
"route-map PBR" should be referring to a route-map and not directly to an ACL. Please refer to the following document for more information.
https://supportforums.cisco.com/docs/DOC-5061
Sorry Harold, i forgot to  mention route configuration in my post.
i have edited my post.
Now if you see full configuration above.
is it logically correct?  i mean can i use same Route Map Name and Same ACL Name in above scenario? or i need to build 3 route maps and 3 ACL?
Why are you using static NAT to do this ?
I would  use dynamic NAT if the communication is always initiated by your hosts and would do something like this:
ip nat pool pool1 2.2.2.1 2.2.2.1 prefix-length 24
ip nat pool pool2 2.2.2.2 2.2.2.2 prefix-length 24
ip nat pool pool3 2.2.2.3 2.2.2.3 prefix-length 24
ip nat inside source route-map pool1 pool pool1
ip nat inside source route-map pool2 pool pool2
ip nat inside source route-map pool3 pool pool3
access-list 100 permit ip host 1.1.1.1 host 150.150.150.150
access-list 101 permit ip host 1.1.1.2 host 150.150.150.150
access-list 102 permit ip host 1.1.1.3 host 150.150.150.150
route-map pool1 permit 10
match ip address 100
route-map pool2 permit 10
match ip address 101
route-map pool3 permit 10
match ip address 102
Alain
Actually, Connection can be originated from any side, so that is why i need static natting.
you created three different route map and ACL.
isnt the way i did, by using single ACL and single Route map, this be accomplished? though in my configuration, it some times work, some times dont.
so i wanted to clarify that part. single route map + single ACL ( and if not then Why? )
OR
Multiple Route map and Multiple ACL ( Although it will make my config tooooo long in case i have more IP's )
