11-18-2013 09:56 AM - edited 03-04-2019 09:36 PM
The infrastructure in place is a Cisco 1921 with primary Internet connectivity via a cable ISP. Backup connectivity is to be provided by VZW with dynamic IP address. Failover is doing with IP SLA tracking, but the issue is not that far into the configuration.
The cellular interface stays up and stable with a negogiated IP address with no issues. However, the second I point my default route towards to the cellular interface, the interface resets (continues to flap until default is removed). To me this sounds like a source nat issue that others have experienced. If I point smaller subnets towrards the cellular interface, it works fine. It seems like it's only when it's the default route that that the issue occurs.
I've run numerous debugs and verified my NAT translations to be accurate. I am still suspicious that Verizon is detecting a NAT violation, but I see nothing that could be causing that. Attached is the config snipet (very basic) in hopes someone can shed some light on this for me:
track 1 ip sla 1 reachability
delay down 30 up 30
interface Cellular0/1/0
description to VZW
ip address negotiated
no ip unreachables
ip nat outside
interface GigabitEthernet0/0
description to Cable ISP
ip address X.X.X.94 255.255.255.252
ip nat outside
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip sla auto discovery
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0
threshold 500
frequency 10
ip sla schedule 1 life forever start-time now
route-map VERIZON-NAT permit 10
match ip address 105
match interface Cellular0/1/0
route-map CABLE-NAT permit 1
match ip address 104
match interface GigabitEthernet0/0
ip nat inside source route-map CABLE-NAT interface GigabitEthernet0/0 overload
ip nat inside source route-map VERIZON-NAT interface Cellular0/1/0 overload
access-list 104 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip any any
ip route 0.0.0.0 0.0.0.0 X.X.X.93 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 track 1
Thx,
Jon
11-18-2013 10:07 AM
Jon
I wonder why you are using track 1 on the static default route using the cellular interface. The reason for tracking the route through the cable interface is clear but why do you need to track the cellular?
I also wonder why the static default route using the cellular is not configured as a floating static? If the intent is that the primary outbound will be cable and that cellular should be backup it would seem more logical that the cellular route should be a floating static rather than a normal static with default admin distance.
I am not sure what difference it will make but I will suggest that you re-write the access lists used to select the traffic to translate. Rather than having extended access lists that permit any destination configure the access lists as standard access lists that permit the source addresses that matter to you.
Give these suggestions a try and let us know if the behavior changes?
Rick
11-18-2013 10:13 AM
Sorry I typed this a little distracted. There is indeed a weight on the Cellular default route and the track is only on the primary link (thanks for noting that)...my apologies. See corrected config below:
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 250
The reason why ACL 105 is permitting any was a troubleshooting measure. This way there is no chance any traffic would leave that interface without being natted. I did have an ACL matching on the specific network I wanted to nat (the 10.1.1.0/24) and it made no difference.
Thank you.
11-18-2013 10:27 AM
Jon
Thank you for the clarification about the static routes and the tracking. It is good to know that my suggestions there were on target.
I understand, and agree, with the logic that the access list for translation on the cellular should permit any. The point that I was trying to make was the difference between using an extended access list and a standard access list. You are not doing anything in either of the translation access lists that requires the capabilities of an extended access list and you can achieve the desired results with a standard access list. I have seen some situations where odd things might happen in address translation where the access list was extended with permit any for the destination.
Rick
