NAT Issues
Robert Craig
Level 3
Level 3
Hey people. I am trying to do some simple NAT'ing (at least I think it's simple) between the WAN and my LAN. My provider gives me three ip's right now and I want to use at least two of them. One of them is already assigned to the WAN interface, but the other two I know I need to do a static nat in order to host any statements. Below is my config with relevant pieces. Does anyone see what I am missing?
interface FastEthernet0/0
description WAN Connection via COX
ip address X.X.209.53 255.255.255.224
ip nat outside
ip inspect FW out
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1.2
description VLAN 2 - Data
encapsulation dot1Q 2
ip address 192.168.15.1 255.255.255.192
ip nat inside
This is what I have right now.
ip nat source static tcp 192.168.16.5 25 X.X.209.53 25 extendable <<-Took this out because it wasn't needed
ip nat source static 192.168.15.14 X.X.209.54  <<--Sharepoint Portal
ip nat inside source static tcp 192.168.16.5 25 interface FastEthernet0/0 25
ip nat inside source static tcp 192.168.16.5 443 interface FastEthernet0/0 443
ip nat inside source route-map LAN-TO-WAN-NO-NAT interface FastEthernet0/0 overload
The way I am looking at it, I should be able to ping the 209.54 address and browse to it form the web, but I can't. There is no firewall right now. The two statements that use F0/0 work great, but I was only able to make it work on that IP with that statement. When I tried
It wouldn't work. Am I missing something? I don't want the entire IP open to the public, I just want to open up holes for 443 and 80. But, I guess I don't understand how to put in the statements and which blank is for what IP. Any help is appreciated.
5 Replies 5
Robert Craig
Level 3
Level 3
Well, I made some progress. I figured out that I had to have a static nat statement for both inside and outside.
So, I had to have this.
ip nat inside source static tcp 192.168.15.14 443 X.X.209.54 443
ip nat outside source static tcp X.X.209.54 443 192.168.15.14 443
So, to me, I need to define what happens when the traffic goes into the "nat cloud" in either direction. I kind of get that. However, if that is the case, why does this work?
I can delete everything else, (minus the overload line) and requests inbound from the internet will work on 443. I don't understand the requirement in one scenario but not the other.
Hello Robert,
Actually you do not need to do both statements ( Ip nat inside and Ip nat outside)
So let's start from here ( You want to be able to access port 443 on ip address X.X.209.54
So all we need is:
ip nat inside source static tcp 192.168.15.14 443 x.x209.54 443
That's all we need to make the translation work! because of Proxy-Arp
Can you do a show ip nat translations | include :443 and provide us the ouptut??
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
OK, will do. I'll change the statements to reflect only the inside direction and test it. I'll run that command as well and give you the output. Let me ask you this, in the example of
It works that way for X.X.209.53 (ip of F0/0). However, if I change the above statement to use the IP instead of F0/0, it fails. Whats the difference?
It should not fail as the router uses Proxy arp!
We will need to determine if the traffic is indeed reaching the router,
do the following
ip access-list extended test_in
permit tcp any host ip_instead_of_f0/0 eq 25
permit ip any any
ip access-group test_in in
Then try to connect and provide the
show access-list test_in
Julio Carvajal
OK, sorry for the wait. Below is what the original config looked like.
ip nat inside source static tcp 192.168.15.14 443 X.X.209.54 443 extendable
ip nat outside source static X.X.209.54 443 192.168.15.14 443 extendable
Then I removed the last line
Then I used that access list to catch the traffic
tcp X.X.209.53:1088 X.X.209.54:1088 216.82.2.9:443   216.82.2.9:443
tcp X.X.209.53:3072 X.X.209.54:3072 216.82.2.9:443   216.82.2.9:443
tcp X.X.209.53:4928 X.X.209.54:4928 216.82.2.9:443   216.82.2.9:443
tcp X.X.209.54:443 192.168.15.14:443  180.94.81.139:51067 180.94.81.139:51067
tcp X.X.209.54:443 192.168.15.14:443  180.94.81.139:51068 180.94.81.139:51068
tcp X.X.209.54:443 192.168.15.14:443  ---                ---
tcp X.X.209.53:16  192.168.15.66:443  192.168.1.9:55896  192.168.1.9:55896
tcp X.X.209.53:443 192.168.16.5:443   109.235.205.50:60574 109.235.205.50:60574
tcp X.X.209.53:443 192.168.16.5:443   ---                ---
So I guess my next test is to change the statements from F0/0 to the IP on the interface. I would think it would still work. Agreed?
