NAT not NAT
hsnanua2011
Dear all,
This is a very simple question, but i am at my wits end for this.
I am trying to perform NAT. I have an ip address (spare) which is 211.23.2.249. The real router ip address is 211.23.2.250.
Anyway, this is an ASA.
What has been done is
1.
access-list IPADDRESSES extended permit ip 10.103.0.0. 255.255.0.0 host 213.23.23.21
2.
global (outside) 10 211.23.2.249
3.
nat (inside) 10 access-list  IPADDRESSES
This should tranform all 10.103.0.0/16 to 211.23.2.249 right?
But its not happening. I tried pinging the 211.23.2.249 but timeout.
Help me..
hsnanua2011
Hi, an addition
This is what i get
vpn# sh nat
match ip inside IPADDRESSES 255.255.255.0 inside host 214.43.34.2
   dynamic translation to pool 10 (No matching global)
The ip address 211.23.2.249 is an unused ip. I cant ping it also from any hosts.
Help
It will only nat if the destination ip is 213.23.23.21 as this what you have specified in your access list IPADRESSES
Is that what you want? Or do you want them to be NAT ed for all destinations in that case change the destination from host x to any any in your address list and make sure you don't have overlapping nat statements
True. But this would be a more confusing situation. Initially, we were trying to make a VPN tunnel with an external host, but even phase 1 failed. We taught that the NAT-ing could be the issue.
Is there any way to eliminate this worry? To test wheteher the NAT is working fine, besides relying on the power of command line accuracy?
Thanks!
