NAT on 2501 problem
devang_etcom
Level 7
Level 7
I am having cisco 2501 series router with one ethernet port. I have my isp connection connected to switch (DLINK nonmanagable, router is also connected to the DLINK nonmanagable link using ehternet port. my isp had given me 172.16.102.x (given to router ehternet port) ip address and they r bindin this ip with router ethernet mac address. now i am having 4 pc connected to my lan(SWITCH) having ip addressing 192.16.1.xx.
is it possible to assign secondary ip of my router ethernet port as 192.168.1.1 can i NAT it with my primary ip which is provided by my ISP whcih is 172.16.102.x so my local lan can access internet...or if any body having other solution for providing internet to lan through router then please help me.....
my cisco ios is 12.0(14) and i am having only one ethernet port on my router...
regards
devang
nethelper
Level 3
Level 3
Hello Devang,
try the following configuration:
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Ethernet0
ip address 172.16.102.x y.y.y.y
ip address 192.16.1.x y.y.y.y
ip nat outside
ip policy route-map NAT
ip nat inside source list 1 interface Ethernet0 overload
access-list 1 permit 172.16.102.x y.y.y.y
route-map NAT permit 10
match ip address 1
match interface Loopback0
Nethelper
hi
I feel Nethelper has missed to add the secondary keyword for the ip address under the ethernet interface which you want to mention as the secondary ip address..
regds
Edwin is right, I forgot that.
interface Loopback0
interface Ethernet0
ip address 192.16.1.x y.y.y.y secondary
ip nat outside
match ip address 1
Nethelper
