NAT outside problem
tprochazka
Hi all,
currently I face problem with outside nat translation and Im not sure how to solve it.
I gotta 881 router
int vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
int vlan 2
ip address 20.20.20.1 255.255.255.0
ip nat inside
int fa0/0
ip address 1.1.1.1 255.255.255.252
ip nat outside
and remote server 100.100.100.25 routed to interface fa0/0.
So the problem is that hosts from Vlan 1 and Vlan 2 want to communicate to this server, but they cannot route, which means, that
I have to "give" them some IP from their range as fake address of this server and translate it.
So I did
ip nat outside source static 100.100.100.25 10.10.10.7 (for Vlan 1)
ip nat outside source static 100.100.100.25 20.20.20.7 (for Vlan 2)
but I get
% 100.100.100.25 already mapped (10.10.10.7 -> 100.100.100.25)
Do somebody know how to solve this issue? As far as I understand router doesnt allow this translation, because if the communication would be started from outside (initial packet would come from server side), router wouldnt know how to translate its source address...
Thanks in advance for some solution.
paolo bevilacqua
100.100.100.25 is a server on the internet? Sorry, I don't understand the problem.
Jon Marshall
Your error message is because you have mapped 100.100.100.25 to 10.10.10.7. You can't then map it to 20.20.20.7 also as the router wouldn't know which address to use.
But why do you need to do this. Surely vlan 1 and vlan 2 clients send all their traffic for remote destinations to the router on their respective vlan interfaces. So why do you need to NAT. All the router needs is a default-route pointing out to the internet  ie.
ip route 0.0.0.0 0.0.0.0
so if a client on vlan 1 sends traffic to 100.100.100.25 it will go to the vlan 1 interface on the router. The router will then forward the packet to the ISP next-hop.
You will however need to NAT the client addresses ie. something like this should be in your config -
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 101 permit ip 20.20.20.0 0.0.0.255 any
ip nat inside source list 101 interface fa0/0 overload
Edit - you shouldn't but if you get issues with NAT between the 2 networks change the acl 101 to -
access-list 101 deny ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
access-list 101 deny ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
Jon
