NAT OVERLOAD NOT WORKING! Don´t understand why?
ranishemer
I have a Cisco 829F Router
I configure basic NAT overload on it is not working! i really need help! like urgent style!
below i attach a image of the topogy
this what the debug is telling me:
Apr 23 19:43:00.187: NAT: API parameters passed: src_addr:192.168.1.54, src_por
t:0 dest_addr:192.168.1.255, dest_port:0, proto:17 if_input:FastEthernet8 pak:88
F54090 get_translated:1
*Apr 23 19:43:00.187: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:00.187: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.54, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:43:01.979: %LINK-3-UPDOWN: Interface FastEthernet8, changed state to
up
*Apr 23 19:43:01.983: NAT: API parameters passed: src_addr:192.168.1.1, src_port
:0 dest_addr:255.255.255.255, dest_port:0, proto:17 if_input:FastEthernet8 pak:8
8F54090 get_translated:1
*Apr 23 19:43:01.983: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:01.983: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.1, src-port:0) (dest-addr:255.255.255.255, dest-port:0)
*Apr 23 19:43:02.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et8, changed state to up
*Apr 23 19:43:04.919: NAT: API parameters passed: src_addr:192.168.1.17, src_por
t:0 dest_addr:255.255.255.255, dest_port:0, proto:17 if_input:FastEthernet8 pak:
88F54090 get_translated:1
*Apr 23 19:43:04.919: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:04.919: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.17, src-port:0) (dest-addr:255.255.255.255, dest-port:0)
*Apr 23 19:43:05.295: NAT: IP address has changed on interface FastEthernet8 : 1
92.168.1.61
*Apr 23 19:43:05.383: NAT: API parameters passed: src_addr:192.168.1.48, src_por
*Apr 23 19:43:05.383: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:05.383: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.48, src-port:0) (dest-addr:255.255.255.255, dest-port:0)
 IL,OL
.168.1.48, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:43:05.571: NAT: API parameters passed: src_addr:192.168.1.30, src_por
*Apr 23 19:43:05.571: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:05.571: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.30, src-port:0) (dest-addr:255.255.255.255, dest-port:0)
 IL,OL
.168.1.30, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:43:06.331: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet8 assigned D
HCP address 192.168.1.61, mask 255.255.255.0, hostname R1-Bontix
*Apr 23 19:43:07.923: NAT: API parameters passed: src_addr:192.168.1.30, src_por
*Apr 23 19:43:07.923: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:07.923: NAT: API Failed to get Translated-Info from: (src-addr:192
*Apr 23 19:43:11.323: NAT: API parameters passed: src_addr:192.168.1.22, src_por
*Apr 23 19:43:11.323: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:43:11.323: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.22, src-port:0) (dest-addr:255.255.255.255, dest-port:0)
 IL,OL
.168.1.22, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:43:18.331: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Apr 23 19:43:19.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Apr 23 19:43:20.503: NAT: API parameters passed: src_addr:192.168.2.2, src_port
:0 dest_addr:192.168.2.255, dest_port:0, proto:17 if_input:GigabitEthernet0 pak:
88F358D8 get_translated:1
*Apr 23 19:43:23.799: NAT: API parameters passed: src_addr:192.168.2.2, src_port
:0 dest_addr:255.255.255.255, dest_port:0, proto:17 if_input:GigabitEthernet0 pa
k:88F358D8 get_translated:1
*Apr 23 19:43:26.503: NAT: API parameters passed: src_addr:192.168.2.2, src_port
88F358D8 get_translated:1sh ip nat translations
R1-Bontix#sh ip nat translations
R1-Bontix#
R1-Bontix#
*Apr 23 19:43:43.331: NAT: API parameters passed: src_addr:192.168.2.2, src_port
R1-Bontix#sh
*Apr 23 19:44:02.799: NAT: API parameters passed: src_addr:192.168.1.5, src_port
:0 dest_addr:192.168.1.255, dest_port:0, proto:17 if_input:FastEthernet8 pak:88F
*Apr 23 19:44:02.799: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:44:02.799: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.5, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:44:08.071: NAT: API parameters passed: src_addr:192.168.1.36, src_por
*Apr 23 19:44:08.071: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:44:08.075: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.36, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:44:15.343: NAT: API parameters passed: src_addr:192.168.2.2, src_port
*Apr 23 19:44:15.347: NAT: API parameters passed: src_addr:192.168.2.2, src_port
*Apr 23 19:44:35.695: NAT: API parameters passed: src_addr:192.168.1.16, src_por
*Apr 23 19:44:35.695: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:44:35.695: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.16, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:44:56.823: NAT: API parameters passed: src_addr:192.168.1.16, src_por
*Apr 23 19:44:56.823: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:44:56.823: NAT: API Failed to get Translated-Info from: (src-addr:192
*Apr 23 19:45:06.783: NAT: API parameters passed: src_addr:192.168.1.34, src_por
*Apr 23 19:45:06.783: ipnat_api_translated_address_and_port_common, out->in want
 IL,OL
*Apr 23 19:45:06.783: NAT: API Failed to get Translated-Info from: (src-addr:192
.168.1.34, src-port:0) (dest-addr:192.168.1.255, dest-port:0)
*Apr 23 19:45:17.363: NAT: API parameters passed: src_addr:192.168.2.2, src_port
*Apr 23 19:45:17.367: NAT: API parameters passed: src_addr:192.168.2.2, src_port
*Apr 23 19:45:30.803: NAT: API parameters passed: src_addr:192.168.1.45, src_por
*Apr 23 19:45:30.803: ipnat_api_translated_address_and_port_common, out->in wan
SHOW RUN
some config are remove for security
Current configuration : 1585 bytes
! Last configuration change at 19:07:38 UTC Thu Apr 23 2015
version 15.2
hostname R1-Bontix
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool silver
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
 option 150 ip 192.168.2.1
no ipv6 cef
license udi pid CISCO892F-K9 sn FTX172885ZG
redundancy
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
 media-type rj45
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet8 overload
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
 login
 transport input all
end
R1-Bontix#
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi,
i don't see any static default route on your router.
could you post a show ip interface brief?
also, kindly add ip route 0.0.0.0 0.0.0.0 dhcp and add a DNS server on your DHCP pool dns-server 8.8.8.8 or an import all
Ok i will do it when i can, because i really need help!
Did you see my Network Topology?
Can i do a ip route to Ethernet interfaces?
R1-Bontix#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.1.1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0
L        192.168.1.3/32 is directly connected, GigabitEthernet0
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, FastEthernet8
L        192.168.2.1/32 is directly connected, FastEthernet8
R1-Bontix#sh ip na
R1-Bontix#sh ip int brie
R1-Bontix#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES unset  administratively down down
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              unassigned      YES unset  administratively down down
FastEthernet5              unassigned      YES unset  administratively down down
FastEthernet6              unassigned      YES unset  administratively down down
FastEthernet7              unassigned      YES unset  administratively down down
FastEthernet8              192.168.2.1     YES NVRAM  up                    up
GigabitEthernet0           192.168.1.3     YES DHCP   up                    up
NVI0                       192.168.2.1     YES unset  up                    up
Vlan1                      unassigned      YES unset  administratively down dow
logoz7
Were you able to solve this problem because I have the same thing on a cisco 2951.
post your config. The initial poster seemed to not have a default route configured...
