12-27-2021 09:05 AM - edited 12-27-2021 09:07 AM
On a C1101-4P two VRFs "ABC" and "DEF" and internet access on G0/0/0.
I'd like to NAT overload both VRFs (VLAN interfaces) to G0/0/0.
Here's the relevant config:
vlan 10 name ABC ! vlan 20 name DEF vrf definition ABC rd 10:10 ! address-family ipv4 route-target export 10:10 route-target import 10:10 exit-address-family vrf definition DEF rd 20:20 ! address-family ipv4 route-target export 20:20 route-target import 20:20 exit-address-family interface GigabitEthernet0/0/0 description #W UPLINK-TO-INET ip address 1.2.3.1 255.255.255.248 ip nat outside media-type rj45 negotiation auto interface Vlan10 description #C ABC vrf forwarding ABC ip address 192.168.9.254 255.255.255.0 ip nat inside standby version 2 standby 10 ip 192.168.9.1 standby 10 priority 110 standby 10 preempt standby 10 name ABC interface Vlan20 description #C DEF vrf forwarding DEF ip address 172.16.0.254 255.255.255.0 ip nat inside standby version 2 standby 20 ip 172.16.0.1 standby 20 priority 90 standby 20 preempt standby 20 name DEF ip nat inside source list ABC interface GigabitEthernet0/0/0 vrf ABC overload ip nat inside source list DEF interface GigabitEthernet0/0/0 vrf DEF overload ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 1.2.3.2 name #DEFAULT-TO-INET ip route vrf ABC 0.0.0.0 0.0.0.0 1.2.3.2 global name #DEFAULT-TO-INET-VRF-ABC ip route vrf DEF 0.0.0.0 0.0.0.0 1.2.3.2 global name #DEFAULT-TO-INET-VRF-DEF
For testing purposes I have a Loopback Lo0 with IP 50.50.50.50/32 in Global routing table. Also, HSRP is not in use (second device not active).
I'm able to reach the IP's 192.168.9.254 and 192.168.9.1 from my client. But never the IP 50.50.50.50 or the INET interface.
Software version is: 17.03.04a (also tried with 16.12.05)
Can someone guide me in the right direction?
Solved! Go to Solution.
12-28-2021
02:22 AM
- last edited on
12-28-2021
07:20 AM
by
Translator
Hello
I wasnt aware you didnt have a valid "next hop", the assumption was that you had.
I am quite sure a NAT rtr cannot translate to itself hence the failure, once you created a valid reachable "nexthop" then translation became appllicable.
12-27-2021
09:27 AM
- last edited on
12-28-2021
07:16 AM
by
Translator
Hello
@dampfhammer wrote:I'm able to reach the IP's 192.168.9.254 and 192.168.9.1 from my client. But never the IP 50.50.50.50 or the INET interface.
Hello
Is the global route table aware of the VRF route tables for the return traffic, Try using "domainless-nat" instead as its nat order of operation is different
int gig0/0
ip nat enable
no ip nat outside
int vlan x
ip nat enable
no ip nat inside
no ip nat inside source list ABC interface GigabitEthernet0/0/0 vrf ABC overload
no ip nat inside source list DEF interface GigabitEthernet0/0/0 vrf DEF overload
ip nat source list ABC interface GigabitEthernet0/0/0 vrf ABC overload
ip nat source list DEF interface GigabitEthernet0/0/0 vrf DEF overload
12-27-2021 11:44 PM
hi Paul
I've made the changes (ip nat enable).
But the
ip nat source list ...
command is not available on the C1101-4P.
I've only the following options:
router(config)#ip nat ? create Create flow entries inside Inside address translation log NAT Logging name Rule name outside Outside address translation pool Define pool of addresses route Establish NAT static routes service Special translation for application using non-standard port settings NAT general settings switchover NAT datapath switchover translation NAT translation entry configuration
After setting the command 'ip nat enable' on the interfaces, I where not able to connect to the router until I added a deny-statement to the ACL 'ABC' like this:
ip access-list extended ABC 10 deny ip 192.168.9.0 0.0.0.255 192.168.9.0 0.0.0.255 20 permit ip 192.168.9.0 0.0.0.255 any
Also, I tried to add a static route in Global VRF to route back VRF traffic:
ip route 192.168.9.0 0.0.0.255 Vlan10
But that didn't help either.
12-28-2021
01:34 AM
- last edited on
12-28-2021
07:19 AM
by
Translator
Hello
I am wondering if this is plaform specific because you are using svi interfaces (vlans), Would it be possible to use subinterfaces instead and test?
int x/x
description lan facing
no shut
int x/x.10
encapsulation dot1Q 10
ip vrf forwarding ABC
ip nat inside
int x/x.20
encapsulation dot1Q 20
ip vrf forwarding DEF
ip address 172.16.0 254 255.255.255.0
ip nat inside
12-28-2021 02:08 AM
Very strange... probably just found the issue!
To test NAT functionality I had only one C1101-4P and tried to reach 50.50.50.50/32 on Lo0 in Global VRF from my client in VRF ABC.
This C1101-4P has it's default route in Global VRF to (1.2.3.2). This IP was NOT reachable (it's a lab...). That's why I created the Lo0.
I grabbed a second C1101-4P, connected the two WAN ports together and configured the IP 1.2.3.2/29 on the second C1101-4P. Now the first C1101-4P router can reach it's default gateway in VRF Global.
On the second C1101-4P I created an Lo0 with 50.50.50.50/32 and deleted the Lo0 on the first one.
Now I can reach the 50.50.50.50 from my client! Here's the NAT and ARP table:
router#show ip nat translations vrf ABC Pro Inside global Inside local Outside local Outside global icmp 1.2.3.1:39679 192.168.9.2:39679 50.50.50.50:39679 50.50.50.50:39679 Total number of translations: 1 router#show ip arp Protocol Address Age (min) Hardware Addr Type Interface Internet 1.2.3.2 7 c44d.8458.1400 ARPA GigabitEthernet0/0/0 Internet 1.2.3.1 - c44d.8458.0280 ARPA GigabitEthernet0/0/0
Seems a strange behaviour when the default gateway is not reachable in combination with a local Loopback.
I really don't have an explanation for this. But the setup itself works so far.
Anyway - thank you for your help Paul.
12-28-2021
02:22 AM
- last edited on
12-28-2021
07:20 AM
by
Translator
Hello
12-28-2021 02:25 AM
Sorry I didn't mention that... Thought the Loopback will do the trick for labing purposes.
Regards, Roland
