NAT/PAT with HSRP
davinci
Please see attached diagram.
I need help setting up NAT/PAT with HSRP.  I want  to setup NAT/PAT so that 172.17.0.0/16 and 172.18.0.0/16 are translated to 200.0.0.1.  200.0.0.1 is the virtual HSRP address.  How can I configure this?
12 Replies 12
Francesco Molino
You need to look at nat redundancy features.
Here a Cisco link showing the configuration:
https://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_nat/configuration/15-2mt/iadnat-ha.html#GUID-0BD7C34A-ADD0-451F-9443-1F0969CF98A0
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hello
Depending on what software you are using depends on what feature is applicable
Eailier software versions you can implement a feature called stateful nat with hrsp however in more recent versions it called box-to-box nat
Kind Regards
Paul
Box to Box NAT seems interesting but I probably wont be able to test in gns3 due to my older gns3 code.
Here is my IOS:
Cisco IOS XE Software, Version 16.09.04
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Versi on 16.9.4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 22-Aug-19 18:09 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
xxxxxxxxxxxxx uptime is 16 weeks, 2 days, 6 hours, 23 minutes
Uptime for this control processor is 16 weeks, 2 days, 6 hours, 25 minutes
System returned to ROM by Reload Command at 05:31:34 CDT Tue Oct 15 2019
System restarted at 05:46:00 CDT Tue Oct 15 2019
System image file is "bootflash:isr4400-universalk9.16.09.04.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is 500000 kbps
Smart Licensing Status: Smart Licensing is DISABLED
cisco ISR4431/K9 (1RU) processor with 1784318K/6147K bytes of memory.
Processor board ID xxxxxxxxxx
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7057407K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Hello
Fyi - I am aware csr1000v vm supports it within gns3
Is this for proof of concept or just interested in learning about stateful hsrp nat or B2B nat
If you provide some additional information i can provide an example for you
are those two rtrs in your topology using the same internal and external ip space and do you wish to have a specifc static translations or dynamic
Kind Regards
Paul
This is proof of concept.  both inside interfaces are in the same subnet and outside interfaces are in the same subnet
example:
outside physical interfaces and HSRP are all in same subnet
inside interfaces are in 10.254.28.160/28.
Only requirement is for all of those /16 networks in cloud to be translated to a single IP address after hitting rtrs.
Hello
You mention an inside subnet of 10.254.28.160/28 but also you wish to nat two /16 subnets , 172.x,x,x/16
Is the an additional routing device between the routers in you OP inside lan interfaces 10.254.28.160/28 and the 172.x.x.x./16 hosts?
Kind Regards
Paul
Yes, there are more routers (not displayed here) between the 172.x.x.x/16 prefixes and my NAT routers.
Hello @davinci
The attached file is an example of B2B HA nat based on your network addressing.
Please note you would require an additional physical link between each nat rtr for the B2B control data to allow the synchronization of the nat translation table.
In this example, any failure of either the inside/outside domain interfaces would initiate a failover to the other nat hrsp router and allow continuous connection the assumption here you already have valid routing place for those lan subnets?
Kind Regards
Paul
thanks, Paul
I don't understand why a direct connection is required between both routers.  Is that more a best practice solution?  They have IP connectivity through the layer 2 switch.
Hello
Its for control traffic between the two rtrs this needs to a be separate link so to synchronise the nat table it cannot be the lan connected interfaces as these are used for data traffic.
If the rtrs were firewalls then you would need a minimum of two additional interfaces for b2b nat control traffic
Kind Regards
Paul
Dear Sir, Your details was informational. However, I have some doubts as im also checking similar config. HSRP configuraiton, im familiar but the syntax used by you below are not familiar. Devies C1800, 2800, 3845. My current scenario is PAT without redundancy, so i'm plannig to make similar setup with redundancy. VIP, i will use private IP and LAN Subnet need to be pat.
redundancy rii 100
redundancy group 1 &
control GigabitEthernet0/0/3 protocol 1
data GigabitEthernet0/0/3
asymmetric-routing interface GigabitEthernet0/0/3
asymmetric-routing always-divert enable
track 3 decrement 100
post your Q in separate, this make all read and answer you
