NAT problem - Can't FTP, port 21 is open
ashgaming
I have a strange problem, I have opened port 21 on my internet facing router however I'm able to use FTP. I get error in FileZilla: "Connection attempt failed. Connection attempt timed out"
Everything works fine and I can FTP if I delete and add again following records in NAT.
ip nat inside source static tcp 192.168.1.13 21 x.x.x.x 21 extendable
ip nat inside source static udp 192.168.1.13 21 x.x.x.x 21 extendable
Am I doing something wrong, do I have to configure on my router something else in order to give FTP access?
Kind Regards
Lukasz
8 Replies 8
Peter Paluch
Hello Lukasz,
FTP opens two TCP ports (UDP is not used). The port 21 is for commands. The another port is for the transferred data itself, and historically, there are two methods of determining that port:
  • Active FTP, in which the client opens the port TCP/20, and the external server connects to this port and starts sending/receiving data as appropriate.
  • Passive FTP, in which the server opens a high TCP port, tells about this port to the client. The client then connects to this port and server starts sending/receiving data as appropriate.
The IOS should take care of enabling this communication over NAT if you open the port 21, however, there may be another features on your router that prevent this communication. Are you running any kind of firewall?
In addition, have you tried reconfiguring the FileZilla for both active and passive FTP operation? Does any of it work?
Best regards,
Peter
I've tried both ftp modes in filezila but still no luck. I have both ports 20/21 opened and it works for couple of hours then stops. I've also tried to restart IIS but still the same I can FTP to this server internaly from my office network.
Lukasz
cadet alain
which ftp mode are you using? have you got firewall or ACLs configured if so could post config.
Regards.
Alain.
Marwan ALshawi
are you using active or passive FTP int the server ?
tyr to use the bellow ACLs example based on the FTP type used
ip access-list extended FROM_OUTSIDE
! Active FTP
permit tcp any host  x.x.x.x 21 range ftp-data ftp
! Passive FTP
permit tcp any host  x.x.x.x 21 eq ftp
permit tcp any host  x.x.x.x 21 range 1023 65535
also u need port 20 in the NAT + 21
I've tried to set up the router with your advice however it didn't work.
I'm probably doing something wrong, would you be able to write it step by step what I should do in order to open ftp port.
My internal ftp server ip is 192.168.1.13, my public IP addres is i.e. 1.2.3.4, this IP is assigned to int fa04 on my router.
Best regards,
Lukasz
can you post you current router config
NAT configuration:
ip nat inside source static tcp 192.168.1.213 20 62.7.74.91 20 extendable
ip nat inside source static tcp 192.168.1.213 21 62.7.74.91 21 extendable
ACL configuration:
Extended IP access list 102
    10 permit tcp any host 1.2.3.4 range ftp-data ftp (230 matches)
    20 permit tcp any host 1.2.3.4 eq ftp
    30 permit tcp any host 1.2.3.4 range 1023 65535 (2252 matches)
    40 permit ip any any (22488719 matches)
!interface fa04
ip access-group 102 in
ashgaming
Thank you all for your advice,
I have enabled both ports 21 and 20 in NAT and I can connected to FTP however after few hours something happens on my router and I can't access FTP unless I readd both ports to NAT.
Below my existing NAT configuration:
ip nat inside source static tcp 192.168.1.13 21 1.2.3.4 21 extendable
ip nat inside source static tcp 192.168.1.13 20 1.2.3.4 20 extendable
I'm using IIS FTP and it runs in default configuration. I haven't specified FTP type to active or passive.
You have mentioned that I should create new ACL shall I do it in following way?
Extended IP access list FTP
    10 permit tcp any host 192.168.1.13 eq ftp
    20 permit tcp any host 192.168.1.13 gt 1024
    30 permit ip any any
I understand that I should enable inbound traffic for above ACL on internet interface?
Best regards and thanku for help,
Lukasz
