NAT problem on ASR920 24Ports
gtomasicchio
Hi everyone. Is it possible to do nat on a 24 port cisco asr920?
Thank you
7 Replies 7
NAT is done in L3 interface' so if these port is config with IP then sure you can use it for NAT
MHM
L2 services, option however supported (but not tested) by the ASR-920-12SZ-IM.
If port is L2 you can not use it for NAT.
There is what we called L2 NAT but this only support in IEEE SW serires
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/industrial/software/configuration/guide/b_l2_nat_ie.html
MHM
Hello
Nat doesn't seem to be supported for this model
Kind Regards
Paul
I appreciate if yoh have doc.' Share it here
Thanks alot
MHM
Hello
check the cfg guides for the ASR920 - here
Kind Regards
Paul
I do not see NAT support listed in either the ASR 920 data sheet or config Guide for any models.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
