NAT problem with EasyVPN/split-tunnel
SLukyanov
Community Member
Hi, everybody!
I have a problem with configuring brach router 891 (with IOS v15.0(1)M).
I want to connect to HQ via EasyVPN connection (split-tunnel) and allow the local traffic to go directly to the Internet via NAT (PAT).
When the VPN connection goes up, NAT stops working and NAT translations don't appear in show ip nat translations. When the VPN connection goes down, NAT begins to work again.
Is it a bug or the intended IOS behavior?
See the fragment of 891's config:
version 15.0
hostname Branch
crypto ipsec client ezvpn EzVPN_to_CO
connect auto
group Branches key *****
mode network-plus
peer 99.99.99.99 default
acl VPN_ACL
virtual-interface 1
username Filial_Router password Filial_Router
xauth userid mode local
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface FastEthernet0/0
description ****** TO LOCAL NET *****
ip address 192.168.0.1 255.255.255.0
ip nat inside
crypto ipsec client ezvpn EzVPN_to_CO inside
interface Serial1/0
description ***** Primary Internet Channel ****
ip address 177.22.100.1 255.255.255.252
ip nat outside
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
ip tcp adjust-mss 1440
ip route 0.0.0.0 0.0.0.0 172.20.100.2 2 track 1
ip nat inside source route-map NAT1 interface Serial1/0 overload
ip nat inside source route-map NAT2 interface FastEthernet0/1 overload
ip access-list extended VPN_ACL
permit ip 192.168.85.0 0.0.0.255 any
ip sla 1
icmp-echo 8.8.8.8 source-interface Serial1/0
frequency 10
ip sla schedule 1 life forever start-time now
access-list 154 permit ip any any
route-map NAT1 permit 10
match ip address 154
match interface Serial1/0
route-map NAT2 permit 10
match interface FastEthernet0/1
end
Hope for your assistance! Thanks!
smitty6504
Level 4
Level 4
Your problem is with your ACLs, the way they are configured are not for a split tunnel. For a split tunnel you would need something like this:
permit ip 192.168.85.0 0.0.0.255 10.0.0.0 0.0.0.255 (Replace 10.0.0.0 0.0.0.255 with the subnets on the other end you need to access)
access-list 154 deny ip 192.168.85.0 0.0.0.255 10.0.0.0 0.0.0.255 (Need to deny anything in your IP access list VPN_ACL.
