NAT problem
3j-kane
how can I ensure that NAT will use the same port when changing the address. At the moment anything using port 7777 incoming is changed to port 2967 when I want it to use 7777?
I've enclosed config + some debug at the bottom of the page.
config deleted
no ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.100 10.0.0.150
ip dhcp pool IP-xxxx
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 212.139.132.4 212.139.132.21
lease infinite
ip name-server 212.139.132.4
ip name-server 212.139.132.21
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
description $ETH-LAN$$FW_INSIDE$
ip address 10.0.0.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
ip inspect SDM_LOW out
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxx
ppp chap password 0 xxxxx
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.111 7777 interface Dialer0 7777
access-list 1 remark INSIDE_IF=FastEthernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp any any eq 7777
access-list 101 permit tcp any any eq 7777 log
access-list 101 permit udp host 212.139.132.21 eq domain any
access-list 101 permit udp host 212.139.132.4 eq domain any
access-list 101 deny ip 10.0.0.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
dialer-list 1 protocol ip permit
snmp-server community public RO
config deleted
Debug Info:
Apr 21 17:39:19.547: TCP: connection attempt to port 7777
Apr 21 17:39:19.547: TCP: sending RST, seq 0, ack 630516979
Apr 21 17:39:19.547: TCP: sent RST to 10.0.0.111:2967 from 81.86.164.235:7777
Edison Ortiz
The translation is working as designed. The external device "81.86.164.235" is requesting data on port "7777" and the router is translating this request to "10.0.0.111", however, this device has a NAT entry using port "2967". I believe is picking that up from the PAT entry "access-list 1 permit 10.0.0.0 0.0.0.255"
Please post the show ip nat trans | i 10.0.0.111 output from this router.
__
Edison.
