NAT-PT and TCP problem
I have 2 IPv4 subnets which are connected to each other via an IPv6 network. For several reasons I don't want to go into here it's better for me to use NAT-PT at the two v4/v6 boundaries instead of creating a v4 tunnel over v6 network.
The result is that I can ping from one v4 host to another v4 host across the v6 network. I can also run UDP/IPv4 traffic across the v6 network, but not with TCP. Does anyone have any suggestion?
Thank you
Hello Joseph,
can you post the configuration of the router where you have NAT-PT configured ?
GP
Hi GP,
The router config I currently have is just for a simple test. I use static mapping for only two v4/v6 pairs. The v4 addresses are the actual addresses of the v4 hosts, while the v6 addresses are bogus and used only to get packets from one side to the other side of the v6 network.
Router 1:
version 12.4
no service pad
hostname xxxx
boot-start-marker
boot system flash:c3725-ik9s-mz.123-5.bin
boot-end-marker
enable password xxxx
no aaa new-model
resource policy
clock timezone EST -5
ip subnet-zero
interface FastEthernet0/0
ip address 10.10.16.100 255.255.255.0
duplex auto
speed auto
ipv6 address 2001:411:1:3:1::/64
ipv6 enable
ipv6 nat
interface FastEthernet0/1
no ip address
duplex auto
speed auto
ipv6 address 2001:411:1:2:2::/64
ipv6 enable
ipv6 nat
ip classless
ipv6 route 2001:411:1:4::/64 2001:411:1:3:2::
ipv6 route 2001:411::/32 2001:411:1:2:1::
ipv6 nat translation timeout never
ipv6 nat v4v6 source 10.10.16.101 2001:411:1:2:2:1:0:1
ipv6 nat v4v6 source 10.10.26.101 2001:411:2:2:2:1:0:1
ipv6 nat v6v4 source 2001:411:1:2:2:1:0:1 10.10.16.101
ipv6 nat v6v4 source 2001:411:2:2:2:1:0:1 10.10.26.101
ipv6 nat prefix 2001:411:1:2:2:1::/96
control-plane
line con 0
transport output all
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxxxxx
login
transport input all
end
Router 2
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname xxxxxxx
boot-start-marker
boot-end-marker
enable password xxxxx
no aaa new-model
resource policy
memory-size iomem 15
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ip ips deny-action ips-interface
ipv6 unicast-routing
ip address 10.10.26.100 255.255.255.0
duplex auto
speed auto
ipv6 address 2001:411:2:3:1::/64
ipv6 nat
no ip address
duplex auto
speed auto
ipv6 address 2001:411:2:2:2::/64
ipv6 nat
ip classless
no ip http server
no ip http secure-server
ipv6 route 2001:411:2:4::/64 2001:411:2:3:2::
ipv6 route 2001:411::/32 2001:411:2:2:1::
ipv6 nat prefix 2001:411:2:2:2:1::/96
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
transport input all
end
Hello Joseph,
when you do a ´show ipv6 nat translations´do you see any TCP translations at all ?
Looking at your configs, I did not see the ´ipv6 unicast-routing´ comand on your Router 1, I assume that command has been configured ?
GP
Hi GP,
Yes I have ipv6 unicast routing on router 1. I must have deleted it by mistake when posting the config file here.
I saw IP translation, yes. The packets went through initially but very soon they stopped. One curious thing: I got the TCP connection, albeit very slow, when sending TCP traffic from Router 1 to Router 2, but when I sent traffic from Router 2 to Router 1, the TCP connections didn't go through. The configs on both routers are identical. The only difference I can detect is the memory size in Router 2 is much smaller than in Router 1. I know it's unlikely that this is the problem but I'm just searching for my way in the dark. What do you think?
Joe
