NAT question Router 800 series
Luis Carranza
Hi all
I didn't a find any discussion related to the issue or question i have right now so here I go:
I need to create a NAT that need to translate a network segment /24 to an IP, something like this
Source: 192.168.10.0/24
NAT: 10.15.3.6
This is the configuration we got right now but it's not working
ip nat inside source static network 192.168.3.0 10.13.4.9 /32
Any thoughts.?
try:
ip nat pool NAT 10.15.3.6 10.15.3.6 netmask 255.255.255.0
ip nat inside source list 1 pool NAT overload
access-list 1 permit 192.168.10.0
conf t
int XXX ## must be your lan
ip nat inside
int YYY ## must be your wan
ip nat outside
ip nat inside source list 102 interface YYY overload   ### enable PAT on your WAN interface using ACL 102
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
end
Regards.
try:
