NAT Question, should I include a 0.0.0.0 network in eigrp. Can't ping pass the router.
petterstergren
Should I include some sort of default path in EIGRP or something?
Im able to ping inside my network, however when trying to ping an IP address outside of my network, one of my core switches is returning a "Destination host unreachable."
version 15.1
hostname Oslo-IntEdge
license udi pid CISCO2911/K9 sn FTX1524SQCT-
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 172.16.2.155 255.255.255.224
 ip nat inside
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 172.16.2.122 255.255.255.128
 ip nat inside
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 172.16.2.186 255.255.255.224
 ip nat inside
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 172.16.1.250 255.255.255.224
 ip nat inside
interface GigabitEthernet0/1.100
 encapsulation dot1Q 100
 ip address 172.16.2.194 255.255.255.248
 ip nat inside
interface GigabitEthernet0/2
 description DMZ
 ip address 172.16.36.30 255.255.255.224
 ip nat inside
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 10
 network 172.16.0.0 0.0.3.255
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static 172.16.36.29 209.165.201.10
ip nat inside source static tcp 172.16.36.28 80 209.209.201.11 80
ip classless
ip flow-export version 9
access-list 1 permit 172.16.0.0 0.0.3.255
version 16.3.2
hostname Core2
ip routing
vtp domain HQ
vtp mode transparent
spanning-tree vlan 1,10,30 priority 0
spanning-tree vlan 20,40,100 priority 4096
vlan 10
 name MGTM
vlan 20
 name IT
vlan 30
 name EMPLOYEE
vlan 40
 name GUEST
vlan 99
 name BLACKHOLE
vlan 100
 name SERVER
interface Port-channel1
 switchport trunk native vlan 99
 switchport trunk allowed vlan 10,20,30,40,100
 switchport mode trunk
 spanning-tree link-type point-to-point
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/22
 switchport nonegotiate
interface GigabitEthernet1/0/23
 channel-group 1 mode active
interface GigabitEthernet1/0/24
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 mac-address 00e0.f94c.5801
 ip address 172.16.2.157 255.255.255.224
 standby 1 ip 172.16.2.158
interface Vlan20
 mac-address 00e0.f94c.5802
 ip address 172.16.2.124 255.255.255.128
 standby 1 ip 172.16.2.126
interface Vlan30
 mac-address 00e0.f94c.5803
 ip address 172.16.2.188 255.255.255.224
 standby 1 ip 172.16.2.190
interface Vlan40
 mac-address 00e0.f94c.5804
 ip address 172.16.1.252 255.255.254.0
 standby 1 ip 172.16.1.254
interface Vlan100
 mac-address 00e0.f94c.5805
 ip address 172.16.2.196 255.255.255.248
 standby 1 ip 172.16.2.198
router eigrp 10
 no auto-summary
ip default-gateway 172.16.2.122
ip classless
version 16.3.2
hostname Core1
no ip cef
ip routing
vtp domain HQ
spanning-tree vlan 20,40,100 priority 0
spanning-tree vlan 1,10,30 priority 4096
vlan 10
 name MGMT
vlan 20
 name IT
vlan 30
 name EMPLOYEE
vlan 40
 name GUEST
vlan 99
 name BLACKHOLE
vlan 100
 name SERVER
interface GigabitEthernet1/0/20
 switchport access vlan 100
 switchport mode access
interface Vlan1
 no ip address
 standby 1 preempt
 shutdown
interface Vlan10
 mac-address 00d0.9736.ec01
 ip address 172.16.2.156 255.255.255.224
 standby 1 priority 110
 standby 1 preempt
interface Vlan20
 mac-address 00d0.9736.ec02
 ip address 172.16.2.123 255.255.255.128
 standby 1 priority 200
 standby 1 preempt
interface Vlan30
 mac-address 00d0.9736.ec03
 ip address 172.16.2.187 255.255.255.224
 standby 1 preempt
interface Vlan40
 mac-address 00d0.9736.ec04
 ip address 172.16.1.251 255.255.254.0
 standby 1 preempt
interface Vlan100
 mac-address 00d0.9736.ec05
 ip address 172.16.2.195 255.255.255.248
 standby 1 preempt
router eigrp 10
 no auto-summary
ip classless
the trunk between the Core switch and the edge router had a native Vlan mismatch. I have changed the native Vlan to 20 on both sides.
The 'ip default-gateway' is used only when the switch is in layer 2 mode. I have removed that and exchanged it with static default routes (in case EIGRP fails for one reason or another).
Attached the revised project file...
petterstergren
The Packet tracer file for the project
Haha your back, Georg you have done it again!
Once again thank you, for sorting out yet another problem!
