NAT Question
itmanager290
8.4(5) ASA 5510
my public Address is #.#.#.26 on the outside interface has a netmask 255.255.255.248. Will I be able to use 27 - 30  for translation also or will it always translate to the .26 address
Thanks In advance....
Actually, highly unlikely. Providers are usually pretty conservative with public IP addresses, so unless you have paid for more than one, everything will be translated to that .26 address.
The one to answer this is your provider...
I have a block of 8 with 6 usable. I will check with them to make sure.
If I Have to use the outside interface is this the setup
Outside rule is any any 3389
NAT
inside Outside PC any 3389 Outside original original
outside Inside any  PC 3389 Original PC   Original
