What is relation among txload/rxload, 5 minute input/output rate and BW?
wfqk
Level 5
Level 5
Hi What is relation among txload/rxload, 5 minute input/output rate and BW? Please see the below highlighted with bold.  We can see txload 47/255 = 18.4%, which is almost equal to 5 minute input rate 1856000 bit/sec. Do you agree on this? And do you think there is any relation with BW 10000 Kbit? If the interface is 10000 Kbit, 18.4% x 10000 = 18400 Kbit /sec. the value 18400Kbit/sec is ten times higher than 5 minute rate 1856000 bit/sec. Any one can explain this? Thank you
ABC3(config-if)#do sh inter e1/0
Ethernet1/0 is up, line protocol is up
Hardware is AmdP2, address is ca03.2a5c.001c (bia ca03.2a5c.001c)
Internet address is 34.1.1.3/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 47/255, rxload 47/255
Keepalive set (10 sec)
Last input 00:00:13, output 00:00:07, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1856000 bits/sec, 176 packets/sec
5 minute output rate 1856000 bits/sec, 176 packets/sec
81130 packets input, 106159662 bytes, 0 no buffer
Received 815 broadcasts, 0 runts, 0 giants, 0 throttles
85000 packets output, 106393891 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
Joseph W. Doherty
For 18.4% (.184) of 10,000, I get 1,840 Kbps, not 18,400 Kbps.
