NAT-Route and Separate Internet Traffic
faisalvt0807
Hello.....!
 Kindly look my attached network diagram
Router 1 is connected to our corporate network 192.168.1.0/24  we are connected into our data centre through a IPSec GRE tunnel VPN
I want to route all the internet traffic through router 2 but VPN should work remain same
Is it possible.? if yes how?
Router 1 current configuration for your reference
ip route 0.0.0.0 0.0.0.0 dialer1
ip nat inside source list NAT interface Dialer1 overload
Extended IP access list NAT
10 permit ip 192.168.1.0 0.0.0.255 any
int dialer1
ip nat outside
int vlan1
192.168.1.1
ip nat inside
2 Accepted Solutions
Philip D'Ath
Change the default route on router 1:
ip route 0.0.00 0.0.0.0 10.1.55.4
Then on router 1 add a route for the subnets going over the VPN, and for the remote VPN end point to go over dialer 1.
ip route <dc subnet> 255.255.255.0 dialer1
ip route <remote vpn end point> 255.255.255.255 dialer1
Router 1 will no longer require any NAT configuration on it.  Router2 will now need to do NAT for 192.168.1.0/24.
The safest option is to use scheduled reboots.
To tell the router to reboot in 10 minutes:
reload in 10
Then make your change.  If it works, execute:
reload cancel
If it doesn't work, wait out the 10 minutes and the router will reboot undoing the change you just made.
16 Replies 16
Philip D'Ath
Thank you...!
I have tested your configuration successfully on my real lab environment. however i'am agitated to do in my production environment because we are using some port forwarding settings.
can you please explain how to tune it based on our new schema. here my current port forwarding settings
R1
ip nat inside source static tcp 192.168.1.1 83 interface dialer1  83
how to push and pull these service from R2 through R1
Can you move the port forwards to R2?
Failing that, what about leaving the routing as it was, and move the VPN to R2?
Those are my preferred options, so that one router is dedicated tot he VPN.  Failing that we can configure a route-map to re-direct some traffic, but it gets a bit messy.
Well...Thank you...!
Yes i can move, i need those port forwarding configuration from you, i'm confused how to configure it on both router
Current configuration
R1
how to change with new scheema
check my thought
R1
ip nat inside source static tcp 192.168.1.1 83 interface vlan2 83
R2
is it correct?
or on R2 ip nat inside source static tcp 10.1.55.1 83 interface dialer1 83
Please help me..........
Whatever that NAT is on R1, copy it un-changed to R2.
What about R1 is there required any static nat, remember my lan interface behind the R1
No, just default route everything to R2.  R2 should have a route for the lan back via R1.
Dear Philip,
Thank's a lot.....!, We are planning to do these changes on upcoming Sunday and i have got approval from the management.
Wish you all the best.................
Good luck.  You'll be fine.
Yes Success...!
I'am coming with one another problem, My location is Dubai we have a remote location in Japan and Moscow there is Cisco 800 series router. in japan there is no one available for support. I wish to do some configuration changes there, which will really affect my basic connectivity with them
my question is, it it possible to configure a default configuration settings to check frequently like every 10 minutes and run if any changes.
Can you send them a console cable and tell them to plug it into a norebook and the router?  If so, get them to pair the notebook with a SmartPhone, and use a remote control app like TeamViewer.  Then you can take over the machine remotely, out of band, and connect to the console port.
Nooo. there is nobody to support me, even i don't know Japanese. so it's very hard for me. that's why i'am checking myself some settings to do in router.
There is no option to roll back previous configuration after a period of time?
reload in 10
reload cancel
Thank you...!, it was usefull
