NAT_RTP issue
MUHAMMED SHAFI
Dear All,
I have cisco 2811 router and ADSL module, router directly connected to switch.
Switch its self conected to some server with astrix VoIP box (ip:10.0.0.100)
i enable nat we can acess all sever out side and inside
if i enable  nat RTP port range 10000 20000 not working  because RTP not extablishing
Please provide  Exact NAT RTP range command
below i mensitoned curent  configurations
Building configuration...
Current configuration : 7530 bytes
! Last configuration change at 08:20:04 UTC Tue Feb 5 2013 by admin
! NVRAM config last updated at 08:09:50 UTC Tue Feb 5 2013 by admin
version 15.1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
--More--        ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-4159471025
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4159471025
revocation-check none
rsakeypair TP-self-signed-4159471025
crypto pki certificate chain TP-self-signed-4159471025
certificate self-signed 01
--More--          3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34313539 34373130 3235301E 170D3132 30393034 31313535
  31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 31353934
  37313032 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100861A 90CEE9A9 EE4E1DB6 8FC0A000 84FB491B 27297AE8 3FBFB45D 54378626
  C8422619 F846B037 1FBC468D 5F06CF94 EFC8A9D3 19AF484D 2526B679 65A0A7F4
  00069710 115FDD28 67C0D9FF 95972773 663A748F C65052F2 3C75FF9E 4E1DD3B3
  8C2A6D8F 11CA8318 CA3044F4 FC930BE9 B403A458 1633E16A 32B7D37E 74B8874B
  8EDB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14586A2D D989E216 424857D8 99B2CEFB 036C2BA6 F6301D06
  03551D0E 04160414 586A2DD9 89E21642 4857D899 B2CEFB03 6C2BA6F6 300D0609
  2A864886 F70D0101 05050003 8181005E E8227570 341563F3 D9302BD0 F0D5DDCF
  9AF7EA0B EA0B9AC5 4DB93819 27974779 1CDA4E2D 03CCBA25 2C09949A 02790AC3
  96FB398E 90B17509 F24E2E4F 0470C60C 11622781 4BF96699 57E9B69D BC55EB06
  A1D95530 BD77D95F 64550DC2 564F84E8 271670E3 280026FE E42D28C8 CFD21B0C
  8B337A0C 80589545 5BA36816 C9413D
  quit
voice-card 0
--More--        !
license udi pid CISCO2911/K9 sn FCZ163373HZ
hw-module pvdm 0/0
username admin privilege 15 secret 4 juA1o5RbDRVqOM1f7nBr4VVBRvkQQxpufT8ellMlsC2
redundancy
controller VDSL 0/0/0
controller VDSL 0/1/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
--More--        !
interface GigabitEthernet0/0
description connected to F/W CORE SW VOIP ISA
ip address 10.0.0.138 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
--More--        !
interface ATM0/0/0.1 point-to-point
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0/0/0
no ip address
shutdown
no fair-queue
interface ATM0/1/0
no ip address
shutdown
interface Ethernet0/1/0
no ip address
shutdown
interface Dialer0
ip address negotiated
ip mtu 1452
--More--          ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.137 21 interface Dialer0 21
ip nat inside source static tcp 10.0.0.137 25 interface Dialer0 25
ip nat inside source static tcp 10.0.0.137 80 interface Dialer0 80
ip nat inside source static tcp 10.0.0.137 110 interface Dialer0 110
ip nat inside source static udp 10.0.0.137 110 interface Dialer0 110
ip nat inside source static tcp 10.0.0.137 135 interface Dialer0 135
ip nat inside source static udp 10.0.0.137 135 interface Dialer0 135
ip nat inside source static tcp 10.0.0.137 143 interface Dialer0 143
ip nat inside source static tcp 10.0.0.137 443 interface Dialer0 443
ip nat inside source static tcp 10.0.0.10 500 interface Dialer0 500
ip nat inside source static udp 10.0.0.10 500 interface Dialer0 500
ip nat inside source static tcp 10.0.0.137 993 interface Dialer0 993
ip nat inside source static tcp 10.0.0.137 1723 interface Dialer0 1723
ip nat inside source static tcp 10.0.0.10 4500 interface Dialer0 4500
ip nat inside source static udp 10.0.0.10 4500 interface Dialer0 4500
ip nat inside source static udp 10.0.0.100 4569 interface Dialer0 4569
ip nat inside source static udp 10.0.0.100 5036 interface Dialer0 5036
ip nat inside source static udp 10.0.0.100 5060 interface Dialer0 5060
ip nat inside source static 10.0.0.100 88.201.31.119 route-map RTP extendable
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 110 permit udp host 10.0.0.100 any range 10000 20000
dialer-list 1 protocol ip permit
route-map RTP permit 10
match ip address 110
control-plane
--More--        !
mgcp profile default
gatekeeper
shutdown
I am waiting for your replay
blau grana
Level 7
Level 7
Hi Muhammed
this might help you.
topology:    INET <==> GW <==> HOST
INET#sh int des
Interface                      Status         Protocol Description
Fa0/0                          up             up       GW
Lo0                            up             up       IP:8.8.8.8
INET#sh cdp nei
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
GW                Fas 0/0            163        R S I      3725      Fas 0/0
GW#sh int des
Fa0/0                          up             up       INET
Fa0/1                          up             up       HOST
GW#sh cdp nei
HOST             Fas 0/1            122        R S I      3725      Fas 0/0
INET              Fas 0/0            172        R S I      3725      Fas 0/0
HOST#sh int des
Fa0/0                          up             up       GW
HOST#sh cdp nei
GW                   Fas 0/0            171        R S I      3725      Fas 0/1
Configuration of nat on GW:
GW#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            100.0.0.2       YES manual up                    up
FastEthernet0/1            192.168.0.1     YES manual up                    up
ip nat pool PORTFWD 192.168.0.10 192.168.0.10 netmask 255.255.255.0 type rotary
ip nat inside source route-map NAT-MAP interface FastEthernet0/0 overload
ip nat inside destination list 100 pool PORTFWD
ip access-list extended NAT_ACL
permit ip 192.168.0.0 0.0.0.255 any
access-list 100 permit udp any any range 10000 20000
access-list 100 permit tcp any any range 15 200
route-map NAT-MAP permit 10
match ip address NAT_ACL
I tested this configuration with tcp packets and it was working fine, so hopefully UDP will be same.
INET#telnet 100.0.0.2
Trying 100.0.0.2 ... Open
User Access Verification
Username: cisco
Password:
HOST>exit
[Connection to 100.0.0.2 closed by foreign host]
INET#
Let us know if this helped you.
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
