NAT Secondary Public IP
drenich
I have 1 2821 router with several IP addresses from a single provider.  The IP addresses are not contiguous.
I would like to NAT different internal subnets to different external IP's.  i.e. map 10.1.1.0 to x.x.220.68 and 10.1.2.0 to x.x.220.70 and 10.1.3.0 to x.x.105.184.
I currently have
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/1 overload
that translates everything to x.x.105.184.
What would be the best way to setup the NAT statements to be able to divide up the subnets?
cadet alain
Try this:
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 102 permit 10.1.2.0 0.0.0.255 any
access-list 103 10.1.3.0 0.0.0.255 any
route-map 101 pemit 10
match ip  address 101
route-map 102 permit 10
match ip address 102
route-map 103 permit 10
match ip address 103
ip pool pool-101  xx.220-68 xx.220.68 prefix-length/32
ip pool pool-102  xx.220.70 xx.220.70 prefix-length /32
ip pool pool-103  xx.105.184 xx.105.184 prefix-length /32
ip nat inside source route-map 101 pool pool-101  overload
ip nat inside source route-map 102  pool  pool-102 overload
ip nat inside source route-map 103  pool  pool-103 overload
Regards.
Alain.
It seems to be close.
It looks like parts of the other subnets are getting stuck in the default deny at the end of access-list 101.  I put deny ip any any log at the end of access-list 101 and it was catching addresses from the other 2 subnets.
Also my IOS version (12.4.(24)T2) does not allow for a prefix-length of 32. The smallest it will go is 30.
Any more thoughts?
Dan
put the prefix-length of the subnet your ip is in.
An ACL in a route-map is not used as when it is as a traffic filter. if there is no match for ACL 101 then route-map 101 will not be used. So it should work this way.
Regards.
Alain.
