NAT SNAT and DNAT at the same time?
switched switch
Hi All,
I have devices on our inside LAN (10.0.0.0/24) that are hardcoded to speak to an IP address: 1.1.1.1. Now 1.1.1.1 is being decomissioned, and I want to ensure that when our internal hosts route attempt to route to 1.1.1.1 they are forwarded to 2.2.2.2 instead (NAT adjusts the destination address).
ip nat outside source static 2.2.2.2 1.1.1.1
I believe the above does it.
But, I also need to ensure that the internal hosts (10.0.0.0/24) are natted to a public address (3.3.3.3) on the same router the above NAT is happening.
So for example when 10.0.0.0/24 route to 1.1.1.1, I want to change the source IP to 3.3.3.3 and change destnation to 2.2.2.2.
When 10.0.0.0/24 sends to anywhere else, just make source IP 3.3.3.3.
ip access-list standard NATPOOL
 permit 10.0.0.0 0.0.0.255
ip nat pool NATPOOL 3.3.3.3 3.3.3.3 netmask 255.255.255.0
ip nat inside source list NATPOOL pool NATPOOL overload
THe issue is when I want to specify the source address as 10.0.0.0/24 going to 1.1.1.1 it doesnt apppear to be getting NATed and the routing is failing.
ip nat pool NATPOOL-2 2.2.2.2 2.2.2.2 netmask 255.255.255.0
ip nat outside source route-map RMAP pool NATPOOL-2
ip access-list extended NAT
 permit ip 10.0.0.0 0.0.0.255 host 1.1.1.1
route-map RMAP permit 10
 match ip address NAT
Can someone assist on the above?
Jon Marshall
So you always want 10.0.0.0/24 to be translated 3.3.3.3 but also 1.1.1.1 to 2.2.2.2 ?
Jon
Hello
Can you try either of these please:
ip nat outside source static 2.2.2.2 1.1.1.1 add-route
or
ip route 1.1.1.1 255.255.255.255 2.2.2.2
res
Paul
Kind Regards
Paul
Hi Paul and John,
Apologies for not replying sooner.
There has been a change in direction on this solution as it appears we are not able to DNAT due to limitations on the systems. Unfortunately because of this, I wasnt able to progress this any further.
Many thanks
