NAT source and destination
sebastian.lemke
Hello friends,
please investigate the attached topology.
I want to do NAT on Router B, and the router shall NAT source and destination of an IP packet. How do I configure this?
Which interface is inside, which is outside?
Is this possible at all?
Hi ,
you can try :
int fa0/1
ip nat inside
int fa0/0
ip nat outside
ip nat source static 192.168.1.2 10.10.10.40
ip nat source static 3.3.3.3 192.168.1.1
Dan
Thanks for your reply. It didn't work unfortunately.
I found an interesting website which helped me finding a solution:
http://blog.ine.com/2008/02/15/the-inside-and-outside-of-nat/
So, basic IP NAT works now! I have configured the following on Router B:
int fa0/0
ip nat inside
int fa0/1
ip nat outside
ip nat inside source static 3.3.3.3 192.168.1.1
ip nat outside source static 192.168.1.2 10.10.10.40
ip route 10.10.10.40 255.255.255.255 192.168.1.2
This config works!
But: Let's go one step ahead: What I exactly need is, to only nat ICMP / SSH / TELNET traffic from 192.168.1.2 to 10.10.10.40.
TELNET and SSH are no big problems, you can use this commands on Router B:
ip nat outside source static tcp 192.168.1.2 23 10.10.10.40 23 extendable
ip nat outside source static tcp 192.168.1.2 22 10.10.10.40 22  extendable
This works fine. But what do I do with ICMP? As ICMP is not running in TCP or UDP, I can't configure it with static NAT.
Please help
