NAT - source ip address
Oleg Volkov
Dear Sirs!
I have a stupid LTE router (Huawei) and I use it as backup link to the internet.
It is router, connected to the Cisco 880 router.
Also, I have primary internet link.
I use Site-to-Site VPN with cypto map (without Tunnel interfaces).
In the remote site, I use subnet 192.168.10.0/24
In the local site, I use subnet 192.168.9.0/24
I use dedicated interface, connected to the Huawei router (Backup).
IP address of the interface is 192.168.8.1.
I use "ip nat outside" on this interface, and use "ip nat inside" on inside interface.
IP address of the Huawei router (his LAN interface) - 192.168.8.2
Huawei does not know abour temote site subnet, because he does not have static routes - it is imposible on this router.
Inside PCs, can access to WEB interface of this router, because they goes throught dynamic NAT (Inside to Backup).
I want to access to the WEB interface of this router, through site-to-site VPN.
I need use NAT, for maping source IP from subnet 192.168.10.0 to IP from 192.168.9.0.
Remote PCs goes throught Outside interface to Backup interface,
On the Outside interface, I have "ip nat outside".
In the Cisco ASA, in case like this, I use nat (outside, backup) source dynamic REMOTE_SUBNET LOCAL_IP destination static BACKUP_SUBNET BACKUP_SUBNET
But I do not know, how do it in the IOS.
Thank!
Helping seriously ill children, all together. All information about this, is posted on my blog
Oleg Volkov
Hello!
I resolved this trouble!
It is not very elegant, but it work.
Huawei ip is 192.168.8.1 192.1
I did make a Loopback and Tunnel interfaces on each router:
RTR1 (with connected Huawei):
interface Loopback1
 ip address 10.80.81.2 255.255.255.255
interface Tunnel1
 ip address 10.80.80.2 255.255.255.252
 ip nat inside
 ip virtual-reassembly in
 tunnel source Loopback1
 tunnel mode ipip
 tunnel destination 10.80.81.1
interface Vlan2 <- here is connected Huawei
 ip address 192.168.8.2 255.255.255.0
 ip nat outside
 ip policy route-map BACKROUTERM
Access-list for route map:
Extended IP access list BACKROUTEACL
    10 permit ip host 192.168.8.1 192.168.0.0 0.0.255.255
    20 deny ip any any
Route-map for backward traffic from Huawei
route-map BACKROUTERM, permit, sequence 10
  Match clauses:
    ip address (access-lists): BACKROUTEACL
  Set clauses:
    ip next-hop 10.80.80.1
In crypto map access-list, we need to add:
permit ip host 10.80.81.2 host 10.80.81.1
ACL for nat traffic to the Huawei:
Extended IP access list HUNATTUNACL
    10 permit ip 192.168.0.0 0.0.255.255 host 192.168.8.1
NAT:
ip nat inside source list HUNATTUNACL interface Vlan2 overload
RTR_Central:
interface Loopback1
 ip address 10.80.81.1 255.255.255.255
interface Tunnel1
 tunnel mode ipip
 tunnel destination 10.80.81.2
permit ip host 10.80.81.1 host 10.80.81.2
And add route to Huawei via Tunnel:
ip route 192.168.8.1 255.255.255.255 10.80.80.2
I think, I can use NVI nat - but I do not like this technology - It may be hard to debugging and understanding, if other people will configure it is routers.
Also, I can use Tunnel interfaces for all VPN traffic, but for it, need to totaly reconfiguration all routers - I lazy today
