NAT static configuration works in 29xx but not in ISR 4331
Hi Everybody,
I have a NAT issue with a ISR 4331 with a working configuration from a 2911 router. When a VPN client tries to connect to 10.226.26.1 port 443 there is not translation to 10.220.202.24. There are matches in VPN_ACL but the VPN client not connect. NAT table isn't registering anything.  This is the configuration:
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no service dhcp
no platform punt-keepalive disable-kernel-core
hostname Office_Router_4520
boot-start-marker
boot system bootflash:isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 40960
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication ppp default local
aaa authorization exec default group tacacs+ none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting nested
aaa accounting exec default
 action-type start-stop
 group tacacs+
aaa accounting commands 0 default
 group tacacs+
aaa accounting commands 15 default
 group tacacs+
aaa accounting network default
 group tacacs+
aaa accounting system default
 group tacacs+
aaa session-id common
clock timezone CRC -6 0
no ip source-route
no ip bootp server
no ip domain lookup
ntp max-associations 2
subscriber templating
key chain EIGRP-key-757
 key 757
   key-string !! SUPPRESSED  !!
license boot level securityk9
redundancy
 mode none
vlan internal allocation policy ascending
interface Loopback0
 description For NAT of VPN clients
 ip address 5.203.140.1 255.255.255.0
 no ip redirects
 no ip unreachables
 ip nat outside
 ip virtual-reassembly
interface Loopback10
 description Remote administration of router
 ip address 10.215.140.1 255.255.255.255
 no ip redirects
 no ip unreachables
interface Loopback26
 description For VPN Nat
 ip address 10.226.26.2 255.255.255.0
 no ip redirects
 no ip unreachables
 ip nat outside
interface Tunnel1
 description Tunnel to HQ via service provider
 bandwidth 2048
 ip address 10.221.140.2 255.255.255.252
 no ip redirects
 no ip unreachables
 ip nat outside
 ip authentication mode eigrp 757 md5
 ip authentication key-chain eigrp 757 EIGRP-key-757
 delay 2000
 tunnel source GigabitEthernet0/0/1
 tunnel destination 10.210.1.1
 tunnel key !! SUPPRESSED  !!
interface GigabitEthernet0/0/0
shutdown
interface GigabitEthernet0/0/1
 description Link to Service Provider
 ip address 10.210.1.140 255.255.255.0
 no ip redirects
 no ip unreachables
 load-interval 30
 negotiation auto
 no cdp enable
interface GigabitEthernet0/0/2
 shutdown
interface GigabitEthernet0/1/0
 description Connection to VPN Client 10.1.3.6
 switchport access vlan 140
 no cdp enable
 spanning-tree portfast
interface GigabitEthernet0/1/1
 description Connection to VPN Client 10.1.3.10
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan140
 description SVI for VPN Clients
 ip address 10.1.3.1 255.255.255.0
 no ip redirects
 no ip unreachables
 ip nat inside
 ip access-group VPN_ACL in
router eigrp 757
 distribute-list 33 in
 network 5.203.140.0 0.0.0.255
 network 10.215.140.1 0.0.0.0
 network 10.221.140.0 0.0.0.3
 passive-interface Loopback0
 passive-interface Loopback10
 passive-interface Loopback26
 passive-interface GigabitEthernet0/0/0
 passive-interface GigabitEthernet0/0/1
 eigrp stub connected
ip nat inside source static 10.1.3.6 5.203.140.6
ip nat inside source static 10.1.3.10 5.203.140.10
ip nat outside source static 10.220.202.24 10.226.26.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface Loopback10
ip access-list extended VPN_ACL
 remark Access of VPN Clients
 remark VPN Client # 4525
 permit tcp host 10.1.3.6 host 10.226.26.1 eq 443
 remark VPN Client # 4526
 permit tcp host 10.1.3.10 host 10.226.26.1 eq 443
 remark Allow ICMP to gateway
 permit icmp 10.1.3.0 0.0.0.255 10.1.3.0 0.0.0.255
 deny   ip any any log
access-list 9 permit 192.168.64.128 0.0.0.15
access-list 9 deny   any log
access-list 10 permit 10.210.1.1
access-list 10 permit 10.211.1.1
access-list 10 permit 192.168.64.128 0.0.0.15
access-list 10 deny   any log
access-list 20 permit 192.168.64.10
access-list 20 permit 192.168.64.11
access-list 20 permit any
access-list 33 permit 10.224.30.0 0.0.0.255
access-list 33 permit 10.220.202.0 0.0.0.255
access-list 33 permit 192.168.64.0 0.0.0.255
access-list 33 permit 192.168.128.0 0.0.0.255
access-list 33 permit 192.168.160.0 0.0.0.255
control-plane
line con 0
 logging synchronous
 stopbits 1
line aux 0
 no exec
 stopbits 1
line vty 0 3
 access-class 10 in
 exec-timeout 5 0
 privilege level 15
 logging synchronous
 transport input telnet ssh
line vty 4
 access-class 9 in
 exec-timeout 2 0
 privilege level 15
 logging synchronous
no network-clock synchronization automatic
ntp authentication-key 1 md5 !! SUPPRESSED  !!
ntp authenticate
ntp trusted-key 1
ntp access-group peer 20
ntp server 192.168.64.10 key 1 prefer source Loopback10
ntp server 192.168.64.11 key 1 source Loopback10
end
show access-lists VPN_ACL
Extended IP access list VPN_ACL
    10 permit tcp host 10.1.3.6 host 10.226.26.1 eq 443 (3 matches)
    20 permit tcp host 10.1.3.10 host 10.226.26.1 eq 443 (3 matches)
    30 permit icmp 10.1.3.0 0.0.0.255 10.1.3.0 0.0.0.255 (4 matches)
    40 deny ip any any log (2 matches)
show ip nat tra
Pro  Inside global         Inside local          Outside local         Outside global
---  ---                   ---                   10.226.26.1           10.220.202.24
---  5.203.140.10          10.1.3.10             ---                   ---
---  5.203.140.6           10.1.3.6              ---                   ---
I really appreciate your help,
Alex
6 Replies 6
try and add:
ip nat outside source static add-route
to your configuration.
Which IOS version are you running ?
Hi Georg,
I tried with that command for nat outside but the result was the same.
The IOS-XE version is Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S6. Image isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin.
Hello
i cannot review you config well from my phone but your nat statements do not look correct - you seem to be applying static outside nat towards an outside interface and also your outside global addressing doesn’t match any wan or VPN subnet and your not specifying tcp port 443 for https
As I said at first glance you nat config looks incorrect - I’m sure other could verify this
res
paul
Kind Regards
Paul
Hi Paul
This is the routing table:
show ip route
Gateway of last resort is not set
      5.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C        5.203.140.0/24 is directly connected, Loopback0
L        5.203.140.1/32 is directly connected, Loopback0
L        5.203.140.6/32 is directly connected, Loopback0
L        5.203.140.10/32 is directly connected, Loopback0
      10.0.0.0/8 is variably subnetted, 18 subnets, 3 masks
C        10.1.3.0/24 is directly connected, Vlan140
L        10.1.3.1/32 is directly connected, Vlan140
C        10.210.1.0/24 is directly connected, GigabitEthernet0/0/1
L        10.210.1.140/32 is directly connected, GigabitEthernet0/0/1
S        10.211.1.0/30 [1/0] via 10.212.140.1
C        10.212.140.0/30 is directly connected, GigabitEthernet0/0/0
L        10.212.140.2/32 is directly connected, GigabitEthernet0/0/0
C        10.215.140.1/32 is directly connected, Loopback10
D EX     10.220.202.0/24 [170/1762048] via 10.221.140.1, 1d00h, Tunnel1
C        10.221.140.0/30 is directly connected, Tunnel1
L        10.221.140.2/32 is directly connected, Tunnel1
D        10.224.30.210/32 [90/1889792] via 10.221.140.1, 1d00h, Tunnel1
D        10.224.30.220/32 [90/1889792] via 10.221.140.1, 1d00h, Tunnel1
C        10.226.26.0/24 is directly connected, Loopback26
L        10.226.26.1/32 is directly connected, Loopback26
L        10.226.26.2/32 is directly connected, Loopback26
If the vpn client with ip 10.1.3.6 tries to connect to 10.226.26.1, the nat outside should translate 10.226.26.1 to 10.220.202.24 and the nat inside translate 10.1.3.6 to 5.203.140.6. But it didn't happen.
When the vpn client tries to connect to 10.220.202.24 (without ACL in) the nat inside translation works and connect.
This seems like the nat outside is not working.
you said the same configuration worked on a 2900 router, can you post that configuration ?
Hello again
I already solved this by moving the loopback 26 to the HQ router and including the 10.226.26.0/24 network in the routing by EIGRP. In this way the nat outside 10.220.202.24 -> 10.226.27.1 worked. Something not very eclectic but effective.
Thanks for your time
