NAT the same port to 2 WAN (router 1812)
rafelmontane
I have configured 2 WAN connections on router 1812.
interface FastEthernet0
description $ETH-WAN$$FW_OUTSIDE$
ip address 88.xx.xx.xx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1
ip address 217.xx.xx.xx 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
And I have two static routes:
ip route 0.0.0.0 0.0.0.0 217.xx.xx.xx
ip route 0.0.0.0 0.0.0.0 88.xx.xx.xx
I like NAT, for exemple, Web port from 2 WAN for view my site over internet. I write:
ip nat inside source static tcp 10.xx.xx.xx 80 interface FastEthernet0 80
It's right and functionaly, but when I add the second NAT for the second WAN it's replace the FE0 configuration:
ip nat inside source static tcp 10.xx.xx.xx 80 interface FastEthernet1 80
I can't not configure the same port on 2 Wan interfaces. What is the problem?
I am newbie on Cisco routers.
Thank you,
Rafel Montané
amritpatek
Level 6
Level 6
For the configuring for the ip nat inside source, generally follow two things
Translates the source of IP packets that are traveling inside to outside and
Translates the destination of the IP packets that are traveling outside to inside.
Below URL help you for the further descripton for the static NAT :
http://www.cisco.com/warp/public/556/12.html#topic9
