Nat to ISP without static public IP
donnymatchen
Hi all.
I have a home setup with a Cisco router and one provided by my ISP.  While I can put the
ISP router,
into bridged mode and allow my Cisco router's GigabitEthernet8 interface to receive an IP address through DHCP, I'm not sure how to configure
NAT.
  I can't know what my public IP will be, or even if I'm the only one
 NATing
through my presently assigned public IP.
The
 ISP router
does not allow
static routing
, or it would be as simple as pointing every subnet at the Cisco router.  Every guide I've found on
NAT
seems to require foreknowledge of a dedicated IP or a range of dedicated IPs.
Any help would be appreciated!
Donny
ammahend
you don't need to know IP, just do
PAT
with overload on interface facing ISP on your router
see example here
-hope this helps-
ammahend
PAT
see example here
-hope this helps-
donnymatchen
worked like a charm, thanks!
