NAT - Translate outside source and destination.
Darren Frowen
I was wondering if anyone could advise on the following issue that we are trying to overcome. We wish to be able to translate both source and destination of an outside (Internet) initiated packet. With the following configuration, we can clearly see both the source and desitnation being trnaslated when it hits the outside interface. However we never see a hit on the IP NAT inside interface to translate back the original packet. We have confirmed that the traffic has returned to the inside interface by way of debug ip packet. We cannot understand why there are not hits on the Inside interface. Please not that there will never by an initiated connection from the inside, connections will only ever be initiated from outside. Any help with this issue would be greatly appreciated.
interface FastEthernet0/0
description Uplink to Firewall_DMZ
ip address 10.10.102.187 255.255.255.192
no ip redirects
no ip unreachables
ip flow ingress
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
description Uplink to Internet_Dirty
ip address 2.2.70.99 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
duplex auto
speed auto
ip nat pool Outside-Local-Source 10.10.102.187 10.10.102.187 prefix-length 26
ip nat inside source static 10.10.102.148 2.2.70.99
ip nat outside source list Outside-Global-Source pool Outside-Local-Source
ip route 0.0.0.0 0.0.0.0 2.2.70.253 name default_route_to_internet
ip access-list standard Outside-Global-Source
permit 82.132.0.0 0.0.255.255
Initiate connection from outside only
Router#sh ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
--- ---                       ---                           10.10.102.187            82.132.234.194
tcp 2.2.70.99:80      10.10.102.148:80     10.10.102.187:34347  82.132.234.194:34347
tcp 2.2.70.99:80      10.10.102.148:80     10.10.102.187:34348  82.132.234.194:34348
---  2.2.70.99           10.10.102.148           ---                             ---
Debug IP nat detail shows outside initiated packet translated source and desitnation
004240: *Apr  3 08:02:49.065 GMT: NAT*: o: tcp (82.132.234.194, 33969) -> (2.2.70.99, 80) [41383]
004241: *Apr  3 08:02:49.065 GMT: NAT*: s=82.132.234.194->10.10.102.187, d=2.2.70.99 [41383]
004242: *Apr  3 08:02:49.065 GMT: NAT*: s=10.10.102.187, d=2.2.70.99->10.10.102.148 [41383]
004243: *Apr  3 08:02:49.501 GMT: NAT: Existing entry found in the global tree,updating it to point to the latest node passed
Debug ip packet shows return packet coming from DMZ but no hit on the IP NAT inside interface
004262: *Apr  3 08:07:27.101 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Stateful Inspection(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004263: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Ingress-NetFlow(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004264: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Virtual Fragment Reassembly(25), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004265: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Virtual Fragment Reassembly After IPSec Decryption(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004266: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, MCI Check(80), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004267: *Apr  3 08:07:27.105 GMT: IP: tableid=0, s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), routed via RIB
004268: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004269: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, output feature, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004270: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, rcvd 3
004271: *Apr  3 08:07:27.105 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, stop process pak for forus packet
004272: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148, len 40, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004273: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, sending
004274: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004275: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004276: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, NAT ALG proxy(55), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004277: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, Post-Ingress-NetFlow(68), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004278: *Apr  3 08:07:27.109 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, sending full packet
004279: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Stateful Inspection(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004280: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Ingress-NetFlow(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004281: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Virtual Fragment Reassembly(25), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004282: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, Virtual Fragment Reassembly After IPSec Decryption(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004283: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, input feature, MCI Check(80), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004284: *Apr  3 08:07:30.481 GMT: IP: tableid=0, s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), routed via RIB
004285: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004286: *Apr  3 08:07:30.481 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, output feature, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004287: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187 (FastEthernet0/0), len 52, rcvd 3
004288: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.148 (FastEthernet0/0), d=10.10.102.187, len 52, stop process pak for forus packet
004289: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148, len 40, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004290: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, sending
004291: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004292: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004293: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, NAT ALG proxy(55), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004294: *Apr  3 08:07:30.485 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, output feature, Post-Ingress-NetFlow(68), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
004295: *Apr  3 08:07:30.489 GMT: IP: s=10.10.102.187 (local), d=10.10.102.148 (FastEthernet0/0), len 40, sending full packetu all
Darren
2 Accepted Solutions
Darren,
you cannot overload when using "ip nat ouside source" command, but there is a workaround for what you are looking for. Use a fictitious subnet for outside translation like 10.10.200.0/24. this way you can have 255 simultaneous connections
Try the following config and check:
ip nat pool Outside-Local-Source 10.10.200.1 10.10.200.255 prefix-length 24
ip nat inside source static 10.10.102.148 2.2.70.100
ip route 10.10.200.0 255.255.255.0 2.2.70.253 name to_send_server_response_outside
yes...correct...but I am assuming that the servers are configured with router's inside ip address as their default gateway, so the return traffic will come back to the router
6 Replies 6
Neeraj Arora
Level 3
Level 3
Darren,
As per me your config is not entirely correct. I understand that you want to a user sitting outside to initiate a connection for the ip address assigned to your FastEthernet0/1 interface & when it reaches your internal private server, the packet should look like its coming from the ip assigned to FastEthernet0/0 interface
There are couple of basic points which you overlooked:
1. Never configure static NAT using the ip addresses assigned to physical interfaces, it always create some unwanted/unforseen issues. And in your config you are using both inside and outside interface ip's as translated ip
2. "ip nat inside" & "ip nat outside" commands are not mentioned in the config above
3. NAT behaves differently while packet going in->out & out->in  ... check the working from the below mentioned link:
Very Basic rule of Network Address Translation (NAT)
http://blog.instruosolutions.com/2012/01/08/very-basic-rule-of-network-address-translation-nat-routers-switches/
Now the reason why you do not see NATing happen when the return traffic is sent from the server is because your server is sending traffic to 10.10.102.187 which is router's inside interface and it never puts that packet on the outside interface, and the rule of NAT says While going out, a packet will only be translated when it hits both Inside & outside interface.
So you need to make some modifications in your config to make it work, here is something which I woudl suggest:
no ip redirects
no ip unreachables
ip flow ingress
duplex auto
speed auto
ip nat inside
no ip redirects
no ip unreachables
ip flow ingress
duplex auto
speed auto
ip nat outside
ip nat pool Outside-Local-Source 10.10.102.190 10.10.102.190 prefix-length 26
ip route 10.10.102.190 255.255.255.255 2.2.70.253 name to_send_server_response_outside
Hope it helps
Neeraj
Dear Neeraj,
Thank you so much for your assistance and configuration reccomendation. You have solved our issue perfectly. We now have the configuration as you have suggested. We have one more issue to be resolved and would be extremely gratefull for any more advice on how to resolve. It appears that we can only achieve a single connection from the outside to inside host. Is there a way of overloading to the 10.10.102.186 address as I do not see the option on a ip nat ouside source command?
description Uplink to Firewall_Facin_DMZ
no ip redirects
no ip unreachables
ip flow ingress
ip nat inside
duplex auto
speed auto
description Uplink to Internet_Facing_Dirty
no ip redirects
no ip unreachables
ip flow ingress
ip nat outside
duplex auto
speed auto
ip nat pool Outside-Local-Source 10.10.102.186 10.10.102.186 prefix-length 26
ip route 0.0.0.0 0.0.0.0 2.2.70.253 name default_to_internet
ip route 10.10.102.186 255.255.255.255 2.2.70.253 name to_send_server_response_outside
ip access-list extended Outside-Global-Source
permit tcp any host 2.2.70.100 eq www
deny   ip any any log
Kindest Regards
Darren
Darren,
Dear Neeraj,
When you say fictitious subnet, this will still have to be routable via the inside network correct? As the server needs to respond to that pool of NAT addresses?
Kindest Regards
Darren
Dear Neeraj,
Actually no the gateway is our Firewall that sits between the router and Host. Completely understand though, we have now asssigned a new pool and everything is working as it should. May I thank you once more for your excellent support.
Kindest Regards
Darren
