05-10-2005 06:05 AM - edited 03-03-2019 09:31 AM
Hi all,
We are having CISCO 836 and Micrsoft SBS 2k3 server. I am trying to configure router so it would be able to allow outside world accessing our web pages on the SBS server (in mz configuration I am using DNS servers provided by my ISP).
After applying NAT translation, the only thing I can do right now is accessing our web pages localy from e.g. 192.168.1.12 (web server is on IP address 192.168.1.5 port 80)
What I don't know is why I cannot reach our web site from outside company? Also, I will setup Exchange server on SBS server and would like to know if there is anything else to consider other than port forwading?
Applying sh ip nat trans ... router responds
router#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
tcp 213.250.XX.XX:80 192.168.1.5:80 --- ---
tcp 213.250.XX.XX:2942 192.168.1.5:2942 193.x.x.11:53 193.189.160.11:53
tcp 213.250.XX.XX:2943 192.168.1.5:2943 193.x.x.11:53 193.189.160.11:53
What I don't understand is why in second line there is tcp 213.250.X.X port 2942 instead of 213.250.X.X port 80 ?
... bellow is router configuration:
Current configuration : 3937 bytes
! Last configuration change at 02:29:55 CEST Tue May 10 2005
! NVRAM config last updated at 02:48:14 CEST Tue May 10 2005
version 12.3
ip dhcp pool CLIENT
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 193.x.x.11 193.189.160.12
lease 0 2
interface Ethernet0
ip access-group 122 out
ip nat inside
interface BRI0
no ip address
shutdown
interface ATM0
no ip address
atm ilmi-keepalive
pvc 1/32
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip access-group 111 in
ip nat outside
ip inspect myfw out
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <removed>
ppp chap password 0 <removed>
ppp pap sent-username <removed> password 0 <removed>
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.5 80 interface Dialer1 80
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 111 permit tcp any any eq telnet
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 deny ip any any log
access-list 122 deny tcp any any eq telnet
access-list 122 permit ip any any
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
05-10-2005 06:21 AM
try and add the following to your access list 111:
access-list 112 permit udp any any eq domain
access-list 112 permit udp any eq domain any
access-list 112 permit tcp any any eq domain
access-list 112 permit tcp any eq domain any
and check if that makes a difference.
GP
05-10-2005 06:57 AM
Hi there,
I have tried, however I think using
SH IP NAT TRANSLATION
still shows wrong ports for example:
router#sh ip nat translation
tcp 213.250.XX.XX:1795 192.168.1.13:1795 206.24.172.62:80 206.24.172.62:80
tcp 213.250.XX.XX:1821 192.168.1.13:1821 206.24.172.62:80 206.24.172.62:80
udp 213.250.XX.XX:4533 192.168.1.14:4533 193.189.160.11:53 193.189.160.11:53
Shouldn't it be the case that under inside global in the second line I should get something like 213.250.XX.XX:80 and that translated to 206.24.172.62:80 which is the outside virtual address of router?
I will try to access the page from my home in about an hour!
Another question, is there anything wrong if I use DNS addresses provided by my ISP even though we are using our own SBS server on our company location?
Thanks in advance and rgds!
Ales
05-10-2005 07:22 AM
I have tried to connect from my home however it doesn't connect .. it responds .. cannot find web page.
Also, why cannot I define two access-groups in my Dilaer 1? I have tried to apply 112 like you said, but then 111 got erased? Should I maybe define that (what I wrote) in access-group 111 or should I redifne my whole access list goup and combine that in 1?
I think what you wrote is ok, however I still need ports 80 in my SH IP NAT TRANSLATION command.
Best regards,
Ales
05-10-2005 07:32 AM
My bad, I red your text poorly so please ignore previous replies!!! I missed 111... I will change like you wrote!
I will test router once again later.
Regards!
Ales
05-10-2005 09:37 AM
Hello again,
I have tried to add it to access-list 111, but no luck, the site is still not reachable.
My access list is not the following:
ip classless
ip http server
access-list 111 permit udp any any eq domain
access-list 111 permit tcp any any eq domain
access-list 111 permit tcp any eq domain any
Also when outside computer tries to access www.company.com, DEBUG IP NAT DETAILED SHOWS the following:
May 10 18:44:15.053: %SEC-6-IPACCESSLOGP: list 111 denied tcp 66.63.172.138(2198) -> 213.250.XX.XX(25), 3 packets
May 10 18:44:15.053: %SEC-6-IPACCESSLOGP: list 111 denied tcp 195.210.255.164(4039) -> 213.250.XX.XX(80), 2 packets
May 10 18:45:18.537: %SEC-6-IPACCESSLOGP: list 111 denied tcp 213.250.60.136(2720) -> 213.250.XX.XX(445), 1 packet
May 10 18:45:18.537: %SEC-6-IPACCESSLOGP: list 111 denied tcp 195.210.255.164(4078) -> 213.250.XX.XX(80), 2 packets
May 10 18:45:18.537: %SEC-6-IPACCESSLOGP: list 111 denied tcp 195.210.255.164(4083) -> 213.250.XX.XX(80), 2 packets
May 10 18:47:30.465: %SEC-6-IPACCESSLOGP: list 111 denied tcp 213.250.16.141(2835) -> 213.250.XX.XX(445), 1 packet
May 10 18:48:08.377: %SEC-6-IPACCESSLOGP: list 111 denied tcp 213.250.16.141(2835) -> 213.250.XX.XX(445), 1 packet
May 10 18:49:21.765: %SEC-6-IPACCESSLOGP: list 111 denied tcp 213.250.60.136(4005) -> 213.250.XX.XX(445),...........etc
For example why the address 213.250.XX.XX port 445 is requested if it is the case that the request is made for port 80 (requesting TCP web site) , isn't it the case that we are translating the address and not ports?
It seems to me that somehow I am not translating the right ports,...any sugestions, anyone?
Rgds,
Ales
06-22-2005 01:55 AM
Jut to let you know, the catch is in command as follows:
access-list 111 permit tcp any any eq www
in case your ISP allows port 80, otherwise one has to specify some other port E.g. port: 81
And that is all to it. Problem wass resolved!
Rgds,
csakos
06-22-2005 05:15 AM
Do you mean that your ISP does not allow port 80 inbound so you had to move your webserver and inbound NAT to 81?
06-22-2005 05:33 AM
Nope, my ISP allows port 80. What I ment was that in case ISP (any ISP) doesn't allow port 80, the access list needs to be formed for another port (E.g. 81) and not port 80.
I have post my answer today incase person with same problems as me can see where and what is the problem in configuration.
Rgds,
csakos
