Nat translations?
Hi guys,
If NAT is configured on a boundary router and is set on the inside and outside interfaces, but show ip nat translations doesn't show any information.
Why might the problem be?
13 Replies 13
Jennifer Halim
Do you pass traffic through the router passing through those interfaces that has inside and outside NAT configured? If there is no traffic going through the router that triggers the NAT translation, there will be nothing in the translation table (sh ip nat trans).
Hi Jennifer,
I'm able to access an external FTP server and transfer files to and from it, but still the sh ip nat translations doesn't show anything!
what version of IOS are you currently running, and can you share the current config?
So "sh ip nat trans" doesn't show anything for any traffic going through the router?
Hello Jennifer,
there is another thread opened by Jory and he/she has reported the NAT configuration.
It looks like he has just defined the NAT pool and the command ip nat inside source  list  pool pool-name is missing
Hope to help
Giuseppe
Ahh, ok, makes sense. I wonder how it still works if it's not NATing, unless public IP is used internally.
Jory, let us know if after adding "ip nat inside souce list pool pool-name" resolve the issue.
Hi guys,
I added the missing NAT commands.
The access-list permit command changes the 10.0.0.0 to 0.0.0.0 by its own!! Is this acceptable?
BTW, I can transfer files to and from an external tftp server.
Configuration:
hostname R1
interface Serial0/1/0
ip address 10.0.0.50 255.255.255.252
ip nat inside
clock rate 64000
interface Serial0/1/1
ip address 1.0.0.37 255.255.255.252
ip nat outside
address-family ipv4
exit-address-family
router ospf 1
log-adjacency-changes
network 10.0.0.48 0.0.0.3 area 0
router bgp 100
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 1.0.0.38 remote-as 200
neighbor 1.0.0.38 ebgp-multihop 2
neighbor 1.0.0.38 update-source Serial0/1/1
neighbor 10.0.0.49 remote-as 100
neighbor 10.0.0.49 update-source Serial0/1/0
address-family ipv4
  redistribute connected
  redistribute ospf 1
  neighbor 1.0.0.38 activate
  neighbor 10.0.0.49 activate
  neighbor 10.0.0.49 next-hop-self
  no auto-summary
  no synchronization
exit-address-family
ip nat pool POOL 1.1.0.0 1.1.0.255 prefix-length 16
ip nat inside source list 1 pool POOL
access-list 1 permit 0.0.0.0 255.255.255.192
ipv6 router ospf 1
Yes, looking good now.
Hi Jennifer,
Still it doesn't work!!
When files are transfered sh ip nat translations issued without any output
Jory,
Try changing your ACL:
to
access-list 1 permit 10.0.0.0 0.0.0.3
HTH,
John
HTH, John *** Please rate all useful posts ***
Jori,
I had thought about my last post and have another question. You only have 2 addresses free on your internal interface. Do you have another appliance behind it that users have to go through? In other words, if you have:
10.0.0.1/30
10.0.0.2/30 (wan on another appliance)
192.168.15.0/24 (internal subnet)
You're going to have to change your ACL to match the users that you want to nat and not the internal interface. In the above scenario, your access-list would change to:
access-list 1 permit 192.168.15.0
Does that make sense?
Hi Jory,
In addition to what John has given, I wanted to know about " ip nat pool POOL 1.1.0.0 1.1.0.255 prefix-length 16"
Your serial outside interface is 1.0.0.0 subnet and when translating you are using 1.1.0.0 subnet. I have no idea about your network setup but I think this should be a problem as well.
Nandan
The only reason why files transfer to the internet work is probably because you have public ip address in your internal subnet, and it works without requiring any NAT. Therefore "sh ip nat trans" is also empty.
Jory, are you using public ip address internally? what ip address are you trying to FTP from and to?
Hi guys,
Here is an inserted image of the topology.
and here are the two used configurations.
Sample configuration 1:
ip nat inside source list 100 interface Serial0/0/1 overload
no access-list 100 permit ip 10.0.0.48 0.0.0.3 any
Sample configuration 2:
ip nat pool POOL 1.0.0.37 1.0.0.37 netmask 255.255.255.252
ip nat inside source list 1 pool POOL overload
access-list 1 permit 10.0.0.48 0.0.0.3
ip nat outside
interface Serial0/0/0
ip nat inside
