Problem getting IPV4 Multicast working over a GRE Tunnel
richard-artevea
I am currently stuck in troubleshooting a problem of multicast data not working over a GRE tunnel joining two networks; I have re-created the problem in a very simple lab network having just two Cisco routers.
I suspect that I have overlooked something in the configuration of the C1921 - ideas/suggestions welcome :-)
Lab network details
Host A <---> Router A <------ IP Cloud ------> Router B <---> Host B
Hosts A and B are PCs running Windows XP Pro
Router A is an old C3620 I had lying around in the lab
Router B is a C1921 from the network in the field I'm having the troube with.
The IP Cloud is a routed network that is not multicast-capable; in the lab this is simulated by an old Linksys cable router having its two Ethernet ports in different subnets. In the field it is provided by a third party telecoms provider (C1800 series routers with Ethernet ports); I do not have any administrative access to their network, but if I needed to make a configuration change and knew exactly what to ask for I could have it done by them...
The problem experienced in the field and in the lab is that:
1. The GRE Tunnel I have created appears to work perfectly for unicast traffic
2. Depending upon where I attempt to put the PIM rendezvous point, multicast traffic does not flow at all, or flows only in one direction.
I tried three tests on the lab system:
In each test, Host A (192.168.200.10) and Host B (192.168.210.50) ran the old Microsoft tool 'MPING.EXE' that sent out packets on the group 225.100.1.1 (and if it received a packet from another sender, would echo it back)
Test #1 - No RP address defined; everything running in dense-mode
Result: One-way communication - Host A received only the first packet from Host B, Host B received all packets from Host A
While the test was running, the output of 'show ip mroute 225.100.1.1' was:
At Router A
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Advertised via MSDP, U - URD,
       I - Received Source Specific Host Report
Outgoing interface flags: H - Hardware switched
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 225.100.1.1), 00:00:49/00:02:59, RP 0.0.0.0, flags: DJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/0, Forward/Sparse-Dense, 00:00:38/00:00:00
    Tunnel0, Forward/Sparse-Dense, 00:00:49/00:00:00
(192.168.200.50, 225.100.1.1), 00:00:37/00:02:59, flags: CTA
  Incoming interface: FastEthernet0/0, RPF nbr 0.0.0.0
    Tunnel0, Forward/Sparse-Dense, 00:00:37/00:00:00
(192.168.210.10, 225.100.1.1), 00:00:49/00:02:59, flags: CTA
  Incoming interface: Tunnel0, RPF nbr 172.16.0.2
    FastEthernet0/0, Forward/Sparse-Dense, 00:00:39/00:00:00
At Router B
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
(*, 225.100.1.1), 00:02:07/stopped, RP 0.0.0.0, flags: DC
    GigabitEthernet0/0, Forward/Sparse-Dense, 00:02:07/stopped
    Tunnel10, Forward/Sparse-Dense, 00:02:07/stopped
(192.168.200.50, 225.100.1.1), 00:01:54/00:01:05, flags: T
  Incoming interface: Tunnel10, RPF nbr 172.16.0.1
    GigabitEthernet0/0, Forward/Sparse-Dense, 00:01:54/stopped
(192.168.210.10, 225.100.1.1), 00:02:06/00:00:53, flags: T
  Incoming interface: GigabitEthernet0/0, RPF nbr 0.0.0.0
    Tunnel10, Forward/Sparse-Dense, 00:01:55/stopped
Test #2 - Sparse-mode, with the RP created in Router A
Interface Loopback1 (10.10.10.10) created in Router A; ip pim rp-address commands entered in both routers poiting at it.
Result: No communication in either direction. Output of 'show ip mroute' command at Router B suggests a problem of registering with the RP.
At Router A
(*, 225.100.1.1), 00:00:35/00:02:59, RP 10.10.10.10, flags: SJC
    Tunnel0, Forward/Sparse-Dense, 00:00:31/00:02:58
    FastEthernet0/0, Forward/Sparse-Dense, 00:00:35/00:02:25
(192.168.200.50, 225.100.1.1), 00:00:34/00:02:59, flags: CTA
    Tunnel0, Forward/Sparse-Dense, 00:00:31/00:02:28
At Router B
(*, 225.100.1.1), 00:01:50/stopped, RP 10.10.10.10, flags: SJCF
    GigabitEthernet0/0, Forward/Sparse-Dense, 00:01:50/00:02:48
(192.168.210.10, 225.100.1.1), 00:01:49/00:01:10, flags: PFT
  Incoming interface: GigabitEthernet0/0, RPF nbr 0.0.0.0, Registering
  Outgoing interface list: Null
Test #3 - Sparse-mode, with the RP created in Router B
Interface Loopback1 (10.10.10.10) deleted from Router A and then created in Router B; ip pim rp-address commands left defined in both routers poiting at it.
Result: One-way communication; host A received all packets from Host B and echoed them back; Host B received nothing.
At Router A
(*, 225.100.1.1), 00:00:31/00:02:59, RP 10.10.10.10, flags: SJCF
    FastEthernet0/0, Forward/Sparse-Dense, 00:00:31/00:02:29
(192.168.200.50, 225.100.1.1), 00:00:30/00:03:29, flags: CFT
    Tunnel0, Forward/Sparse-Dense, 00:00:30/00:03:02
(192.168.210.10, 225.100.1.1), 00:00:26/00:02:59, flags: CJT
    FastEthernet0/0, Forward/Sparse-Dense, 00:00:26/00:02:33
At Router B
(*, 225.100.1.1), 00:01:24/00:03:05, RP 10.10.10.10, flags: SJC
    GigabitEthernet0/0, Forward/Sparse-Dense, 00:01:20/00:02:41
    Tunnel10, Forward/Sparse-Dense, 00:01:24/00:03:05
(192.168.210.10, 225.100.1.1), 00:01:19/00:01:40, flags: T
    Tunnel10, Forward/Sparse-Dense, 00:01:19/00:03:05
(192.168.200.50, 225.100.1.1), 00:01:23/00:01:38, flags: T
Extracts from the router running-configs showing how I created the GRE tunnel:
Router A (C3620)
interface Loopback0
ip address 192.168.200.224 255.255.255.255
interface Tunnel0
ip address 172.16.0.1 255.255.255.252
ip pim sparse-dense-mode
ip ospf network point-to-point
tunnel source FastEthernet0/1
tunnel destination 192.168.250.2
interface FastEthernet0/0
ip address 192.168.200.1 255.255.255.128
interface FastEthernet0/1
ip address 192.168.251.2 255.255.255.0
router ospf 10
redistribute static subnets
network 0.0.0.0 255.255.255.255 area 0
ip route 192.168.200.128 255.255.255.248 192.168.200.66
ip route 192.168.250.0 255.255.255.0 192.168.251.1
Router B (C1921)
interface Loopback0
ip address 192.168.210.224 255.255.255.255
interface Tunnel10
ip address 172.16.0.2 255.255.255.252
tunnel source GigabitEthernet0/1
tunnel destination 192.168.251.2
interface GigabitEthernet0/0
ip address 192.168.210.1 255.255.255.128
interface GigabitEthernet0/1
ip address 192.168.250.2 255.255.255.0
router ospf 10
ip route 192.168.210.128 255.255.255.240 192.168.210.66
ip route 192.168.251.0 255.255.255.0 192.168.250.1
Richard Culpan - Artevea Digital Ltd.
John Blakley
Richard,
It looks like you could be having some rpf failures. To me, the traffic looks like it's going over the tunnel, but the path back to the source is not going over the tunnel:
Router A:
The quick way to fix this, if this is truly the cause, is to add a static multicast route on both routers pointing back to their real ip address:
For example, if the source at A is address 192.168.200.10, then on RouterB your route would be:
ip mroute 192.168.200.10 255.255.255.255 tu0
And do the same on the other side.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks for the quick reply...
It didn't seem to be an RPF failure as the path back to the source was known via OSPF; 'show ip rpf ' was showing the expected path back to that sender.
But in a few hours of tinkering I did eventually come across the real culprit! It was multicast fast-switching. The old C3620 and 2611 routers don't seem to like fast-switching ('ip mroute-cache') on the tunnel interface - turning it off ('no ip mroute-cache' ) fixed the problem. FWIW I noticed that this is also true of legacy serial interfaces (e.g. X.21) - there was a 'no ip mroute-cache' put into the running configuration by default, but not for the tunnel interface.
Network in the field now running with a single static RP (equivalent to 'Router A' in my lab system) and multicast now goes both ways through the tunnel :-)
I'll revisit it another day and try to improve things (e.g. add some resilience by having an "anycast" RP or running separate RPs each side of the tunnel and MSDP to link them together)
