NAT Traversal on a Cisco 881W router
burleyman
Level 8
Level 8
I am running c880data-universalk9-mz.124-20.T4.bin on a Cisco881W router and an ASA5512 with asa915-smp-k8.bin
I need to setup a site to site IPSEC VPN tunnel and not NAT the traffic.
Does the Cisco881W support NAT traversal or don't I need that? If not how would I configure?
Mike
ghostinthenet
Level 7
Level 7
The 881W supports NAT Traversal, but that's really used for running an IPSec endpoint behind another NAT device.
If you just want to make sure that the 881W doesn't NAT IPSec traffic to your ASA, you can do that by denying the IPv4 source and destination addresses in the NAT ACL on the router.
For example, if your IPSec VPN on the 881W sends traffic from 192.168.0.0/24 to 192.168.1.0/24, your NAT configuration would look something like this:
ip nat inside source list ACL_WAN_NAT interface FastEthernet4 overload
ip access-list extended ACL_WAN_NAT
 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.0.0 0.0.0.255 any
With this NAT configuration, traffic from 192.168.0.0/24 to 192.168.1.0/24 will be unmodified while all other traffic from 192.168.0.0/24 will be subject to NAT.
