NAT UDP port range forwarding howto?
jasonkd7tqn
Hi there,
I have been banging my head on my keyboard for hours researching this issue and trying to find a solution.
I need to forward a range of UDP ports (about 100 of them) for a minecraft server I am setting up and for other services on my network and I would like to find the easy way of doing this. I only get 1 dynamic IP assigned by my ISP so static nat wont work for my situation.
The method I have been using to open udp ports is
"ip nat inside source static udp 192.168.1.101 7101 interface FastEthernet0/1 7101"
and thats good and works and all but it isnt verry efficiant as 100 entries like that will clutter up my config.
I have been using the following method to forward TCP ports which works great, just cant get UDP to forward this way.
ip nat pool stream 192.168.1.100 192.168.1.100 netmask 255.255.255.0 type rotary
ip nat inside destination list 105 pool stream
ip access-list extended 105
permit udp any any range 5000 5011
permit tcp any any range 5000 5011
Is there any easy way that anyone knows of to forward UDP port ranges?
thanks.
Setup:
Cisco 1841
IOS version: 12.4(24)t2
1 external interface with 1 ISP dynamic IP
config :
Current configuration : 2792 bytes
version 12.4
hostname SPS700
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
no ip source-route
archive
log config
  hidekeys
interface FastEthernet0/0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
no mop enabled
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool websvr 192.168.1.101 192.168.1.101 netmask 255.255.255.0 type rotary
ip nat inside source static tcp 192.168.1.101 7103 interface FastEthernet0/1 7103
ip nat inside source static udp 192.168.1.100 7100 interface FastEthernet0/1 7100
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside destination list stream pool stream
ip nat inside destination list webevr pool websvr
ip access-list extended Stream
ip access-list extended websvr
permit udp any any eq domain
permit tcp any any eq www
permit tcp any any range 25500 25600
permit udp any any range 25500 25600
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
scheduler allocate 20000 1000
end
chad patterson
would this work?
ip nat inside source static 192.168.1.101 interface FastEthernet0/1 route-map MINECRAFT extendable
ip nat inside source list 101 interface FastEthernet0/1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit udp host 192.168.1.101 any range 25500 25600
route-map MINECRAFT permit 10
match ip address 100
for some reason my router does not allow the command
I can enter "ip nat inside source static 192.168.1.101 interface FastEthernet0/1" but it wont accept route-map after that.
weird...
well the "interface 0/1" should be your public static ip address
Then test it with:
sh ip nat translations | i udp
All NAT configurations with ACL and UDP port ranges do not work;
The solution is quite simple: "ip nat portgrange";
I.e we have the setup:
[SX-20]--------{LAN}[Router 881]{WAN}-------{internet}
SX-20 has IP 192.168.100.10;
R881's LAN interface 192.168.100.1;
R881's WAN interface 100.20.11.200;
IOS version is 15.4(3)M7;
Our configuration must meets the requirements:
1) SX-20 must be able to accept inbound calls from internet;
2) SX-20 must be able to call any video terminal in internet;
3) Network administrator must be able to connect to R881's console via SSH from internet;
!------Configuration------!
interface Vlan2
 description ***LAN***
 ip address 192.168.100.1 255.255.255.0
 no ip redirects
 ip nat inside
 ip virtual-reassembly in
interface FastEthernet4
 description ***WAN***
 ip address 100.200.11.200 255.255.255.0
 no ip redirects
 ip nat outside
ip route 0.0.0.0 0.0.0.0 172.20.11.1
! The ACL below should contains only IP address of SX-20;
ip access-list extended VKS-TERMINAL
 permit ip host 192.168.100.10 any
ip nat portmap RTP-RANGE-PORTMAP
 appl udp-rtp startport 16384 size 16384
! SSH connection to router;
ip nat inside source static tcp 192.168.100.1 22 interface FastEthernet4 22
! HTTP connection to SX-20's web interface
ip nat inside source static tcp 192.168.100.10 80 interface FastEthernet4 80
! Inbound SIP signaling;
ip nat inside source static udp 192.168.100.10 5060 interface FastEthernet4 5060
ip nat inside source static udp 192.168.100.10 5061 interface FastEthernet4 5061
ip nat inside source static tcp 192.168.100.10 5060 interface FastEthernet4 5060
ip nat inside source static tcp 192.168.100.10 5061 interface FastEthernet4 5061
ip nat inside source static udp 192.168.100.10 5062 interface FastEthernet4 5062
! Inbound H.323 signaling;
ip nat inside source static tcp 192.168.100.10 1718 interface FastEthernet4 1718
ip nat inside source static tcp 192.168.100.10 1719 interface FastEthernet4 1719
ip nat inside source static tcp 192.168.100.10 1720 interface FastEthernet4 1720
! The entry below allows SX-20 connect to internet and allows inbound RTP connections;
ip nat inside source list VKS-TERMINAL interface FastEthernet4 overload portmap RTP-RANGE-PORTMAP
