GRE Tunnel Poor Performance
Paul Smith
Hi Guys,
I am having some VPN issues which are starting to creep above my skill level.
I have set up a GRE tunnel between a head office router and a branch office router. When browsing the internet from the branch office through the tunnel I am getting very poor speeds and unusual behaviour. For example I can browse some of youtube (poorly) but I cant even open www.netflix.com
From the research I have done, I am starting to wonder if the issue is related to MTU or TCP MSS .
Let me paste the configs below, along with the router details and hopefully you have a better idea than me?
Head Office Router;
Model - CISCO 2901/K9
IOS - 15.0(1r)M16
HO-WAN-RTR-VPN01#sh ip int tunn 4
Tunnel4 is up, line protocol is up
  Internet address is 169.254.40.1/30
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1300 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain inside
  BGP Policy Mapping is disabled
  Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check, TCP Adjust MSS
  Output features: NAT Inside, Common Flow Table, Stateful Inspection, TCP Adjust MSS, NAT ALG proxy
  Post encapsulation features: IPSEC Post-encap output classification
  IPv4 WCCP Redirect outbound is disabled
  IPv4 WCCP Redirect inbound is disabled
  IPv4 WCCP Redirect exclude is disabled
  interface Tunnel4
 ip address 169.254.40.1 255.255.255.252
 ip mtu 1300
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1379
 tunnel source xxx.xxx.136.210
 tunnel destination xxx.xxx.211.3
 tunnel protection ipsec profile test_profile
end
Branch Office Router;
Head Office Router;
Model - Cisco 871 (MPC8272)
IOS - Version 12.3(8)YI2
Crabmeat#sh int tunn 4
  Hardware is Tunnel
  Internet address is 169.254.40.2/30
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source xxx.xxx.211.3 (Dialer0), destination xxx.xxx.136.210
  Tunnel protocol/transport GRE/IP, key disabled, sequencing disabled
  Tunnel TTL 255
  Checksumming of packets disabled,  fast tunneling enabled
  Path MTU Discovery, ager 10 mins, min MTU 92, MTU 0, expires never
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "ipsec_glink_profile")
  Last input 00:32:33, output never, output hang never
  Input queue: 0/75/310092/0 (size/max/drops/flushes); Total output drops: 233
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 0 bits/sec, 1 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     43379375 packets input, 1453292908 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     38438968 packets output, 3877235423 bytes, 0 underruns
interface Tunnel4
 ip address 169.254.40.2 255.255.255.252
 ip mtu 1300
 ip tcp adjust-mss 1460
 tunnel source Dialer0
 tunnel destination xxx.xxx.136.210
 tunnel path-mtu-discovery
 tunnel protection ipsec profile ipsec_test_profile
end
Joseph W. Doherty
For your tunnels, try IP MTU 1400 and IP TCP adjust-mss 1360.
8 Replies 8
nurbol555
your ip tcp adjust-mss on tunnel different, fisrt side have 1379, second side have 1460, it have to be the same
Joseph W. Doherty
In addition to the other posts, 'tunnel path-mtu-discovery' on the tunnel interfaces might help as well...
Paul Smith
Thanks. These settings made a big difference and fixed most performance issues I was having. Connecting to Netflix still does not work although this may be a seperate issue as the windows box connects fine.
Paul Smith
I would like to elaborate a little further for anyone else experiencing this issue. At this point Netflix is back up and running and I am achieving 6Mbps out of a potential 13Mbps. Not the best but still a massive improvement on what I had. I now have an ip mtu of 1398 and an ip tcp adjust-mss of 1358 on both ends. To arrive at these values I basically I did the ping to the remore router 192.168.212.1 -f -l xxxx, where x was the mtu value that eventually stopped fragmenting. In the end 1370 was just right with 1371 being too high. I then added 28 to get 1398 as is the recommended practice. I then subtracted 40 from that value to get 1358 as is also the recommended practice. I would love to get a 13Mbps download to match the adsl connection but they may not be possible with GRE. I will continue to tweak.
Ah, just caught your mention of aDSL and also just noticed you're using a dialer interface.  I'll presume your aDSL is using PPPoE, usually decreases MTU by 8 bytes. (That would be on the physical aDSL interface.)
Thanks Joseph,
I did actually change the dialer interface to 1492 as it was sitting at 1500. Do you think I should also change Fa4 to 1492 (physical ISP facing)?
I'm unsure - it's been so, so long since I worked with a dialer interface.
Having the dialer interface set to 1492 might be fine, although setting the ISP facing F4 to 1492 should be suitable too.
