NAT with Secondary IP address on interface
jfraasch
Level 3
Level 3
I have a pretty simple router config and want to do something a little strange.
For interface F0/0 I want to add a secondary IP address of 10.125.0.1/24.  Both the current 192.168.1.1 and the 10.125.0.1 networks will be on VLAN 1 for a while.
Will I be able to NAT the 10.125.0.0/25 IPs the same way I am NAT'ing the 192.168.1.0/16 IPs? If so, what do I need to add besides the secondary IP address on F0/0?
interface FastEthernet0/0
ip address 192.168.1.1 255.255.0.0
ip nat inside
duplex auto
speed auto
arp timeout 60
interface FastEthernet0/1
ip address 10.23.63.7 255.255.255.128
ip nat outside
duplex auto
speed auto
arp timeout 60
ip nat inside source static 192.168.32.20 10.23.63.17
ip nat inside source static 192.168.1.250 10.23.63.12
ip nat inside source static 192.168.1.150 10.23.63.10
ip nat inside source static 192.168.1.10 10.23.63.8
ip nat inside source static 192.168.1.22 10.23.63.11
ip nat inside source static 192.168.1.25 10.23.63.13
ip nat inside source static 192.168.1.23 10.23.63.14
ip nat inside source static 192.168.20.32 10.23.63.18
ip nat outside source static 192.168.20.32 10.23.63.17
ip classless
ip route 0.0.0.0 0.0.0.0 10.23.63.1
no ip http server
ip pim bidir-enable
access-list 101 deny tcp 200.200.10.0 0.0.0.255 200.199.11.0 0.0.0.255 eq ftp
access-list 101 permit ip any any
Any help would be appreciated!
James
John Blakley
You can nat out on the secondary address just like you're doing now with no issues....
HTH, John *** Please rate all useful posts ***
