NAT woes.. now DHCP
jbfasulo
Hey Everyone,
I'm trying to configure my Cisco 3725 to NAT overload between four subnets in RFC 1918 space. It's a slash 26 internal NAT network. I'm trying to figure out why i'm not getting out. Maybe I have a VLAN or access-list problem? Here's my configuration:
Thanks!
Current configuration : 2940 bytes
version 12.3
service password-encryption
hostname JohnStark
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.65
ip dhcp excluded-address 192.168.1.129
ip dhcp excluded-address 192.168.1.193
ip dhcp pool DanLAN
   network 192.168.1.0 255.255.255.192
   domain-name DanLAN
   default-router 192.168.1.1
   dns-server 8.8.8.8 192.168.1.1
ip dhcp pool JoeLAN
   network 192.168.1.64 255.255.255.192
   domain-name JoeLAN
   default-router 129.168.1.65
   dns-server 8.8.8.8
ip dhcp pool ExperimentLAN
   network 192.168.1.128 255.255.255.192
   default-router 192.168.1.129
   dns-server 8.8.8.8
ip dhcp pool ManagementLAN
   network 192.168.1.192 255.255.255.192
   default-router 192.168.1.193
ip name-server 8.8.8.8
ip audit po max-events 100
interface FastEthernet0/0
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
switchport access vlan 100
no ip address
interface FastEthernet1/1
no ip address
interface FastEthernet1/2
no ip address
shutdown
interface FastEthernet1/3
no ip address
shutdown
interface FastEthernet1/4
no ip address
shutdown
interface FastEthernet1/5
no ip address
shutdown
interface FastEthernet1/6
no ip address
shutdown
interface FastEthernet1/7
no ip address
shutdown
interface FastEthernet1/8
no ip address
shutdown
interface FastEthernet1/9
no ip address
shutdown
interface FastEthernet1/10
no ip address
shutdown
interface FastEthernet1/11
no ip address
shutdown
interface FastEthernet1/12
no ip address
shutdown
interface FastEthernet1/13
no ip address
shutdown
interface FastEthernet1/14
no ip address
shutdown
interface FastEthernet1/15
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.0.0.2 255.255.255.0
ip access-group 10 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
interface Vlan100
ip address 192.168.1.1 255.255.255.192
ip access-group 10 in
interface Vlan200
ip address 192.168.1.65 255.255.255.192
interface Vlan300
ip address 192.168.1.129 255.255.255.192
interface Vlan400
ip address 192.168.1.193 255.255.255.192
ip nat inside source list 10 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 1.1.1.1
no ip http server
no ip http secure-server
access-list 10 remark Permitted Subnets allowed to internet
access-list 10 permit 0.0.0.0 255.255.255.0
access-list 10 permit any
line con 0
line aux 0
line vty 0 4
login
end
2 Accepted Solutions
Peter Paluch
Hi Joe,
If I understand correctly, you want your privately addressed subnets to be able to access the internet behind Fa0/0, is that correct?
In that case, your Vlan10, Vlan100, Vlan200, Vlan300 and Vlan400 shall be configured with ip nat inside (note that your Vlan10 is currently configured with ip nat outside and other SVIs are not configured for NAT at all).
Next, your ACL 10 is not correct. Usage of permit any is not supported for NAT deployments - you have always to be more specific about your networks. My suggestion is to remove ACL 10 altogether and rework it like:
access-list 10 remark Permitted subnets allowed to access internet
access-list 10 permit 10.0.0.0 0.0.0.255
access-list 10 permit 192.168.1.0 0.0.0.255
Lastly, is your default route correct? It uses a next hop of 1.1.1.1 - is this next-hop IP correct?
Do you believe you could try this out?
Best regards,
Peter
Can you get rid of the ip access-group 10 on the SVIs, I even wonder how DHCPis working on one VLAN because the DISCOVER message has a source IP of  0.0.0.0 and it should get matched by the implicit deny statement in the ACL and so should get dropped.
Alain
5 Replies 5
Peter Paluch
Hi Joe,
Best regards,
Peter
Peter I'll give it a try tonight. Thanks!
Hi Peter,
Your suggestions worked great. I was able to get it working on one vlan. As I started adding others, dhcp stopped working by not handing out addresses. That's one of the last requirements I need. Any ideas? Here's the updated config:
version 12.3
hostname JohnStark
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool DanLAN
   domain-name DanLAN
   dns-server 192.168.1.1 8.8.8.8
ip dhcp pool JoeLAN
   domain-name JoeLAN
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no mop enabled
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
switchport access vlan 200
no ip address
no ip address
no ip address
no ip address
switchport access vlan 300
no ip address
no ip address
switchport access vlan 400
no ip address
no ip address
interface Vlan1
no ip address
interface Vlan100
ip nat inside
interface Vlan200
ip nat inside
interface Vlan300
ip nat inside
interface Vlan400
ip nat inside
ip classless
ip dns server
no ip http server
access-list 10 remark Permitted subnets allowed to access the internet
line con 0
line aux 0
line vty 0 4
login
end
Alain
Cadet Alain,
That was it! The DHCP offers weren't getting back with the current access-list. I added a permit rule for both 255.255.255.255 and 0.0.0.0. It seemed to solve my issues. Cheers!
J
