Nat WRT120N help
kevindurant1
Im trying to open the NAT on xbox 360 but have no luck.
I have my xbox 360, PS3 and 3 laptops connected(wireless) to the router.
I have opened all the ports but it is still on strict. When I connect my xbox straight through my modem, its ok. Its only when I connect it to the router. Any ideas?.
Reza Sharifi
Can the laptops connect via wireless  fine?
yes. I made a new wireless connection and im using ps3 to connect there as well.
