NAT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-20-2017 08:14 AM - edited 03-05-2019 08:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2017 08:57 AM
Are you going to configure it on a firewall or router? There are 3 types of NAT:
- Static NAT
- Dynamic NAT
- PAT (Port Address Translation)
Example of static NAT
It is a NAT for one to one.
interfaces fa0/0
description INTERNAL-NETWORK
ip nat inside
interface fa0/1
description PUBLIC-NETWORK
ip nat outside
ip nat inside source static <Private IP> <Public IP>
Example of dynamic NAT
In this type of NAT you can use a pool of public IP addresses to translate the internal networks to them:
interfaces fa0/0
ip nat inside
interface fa0/1
ip nat outside
ip access-list standard PRIVATE-NET
permit 192.168.0.0 255.255.0.0
ip nat pool TESTPOOL 140.X.Y.10 140.X.Y.12 Netmask 255.255.255.0 (this pool include the IP. 10, 11 and 12 only)
IP NAT INSide SOUrce LIst PRIVATE-NETS pool TESTPOOL
Example of a PAT configuration:
This kind of NAT uses an unique source port number translation, instead of IP address translation. Port Numbers are 16-bit binary numbers and we have 65535 port numbers available. This kind of NAT is commonly used because you don't wast public IP addresses, You only need one Public IP.
Step 1) Configure the interfaces to be inside and outside
interfaces fa0/0
ip nat inside
interface fa0/1
ip nat outside
Step 2) Match the private subnets that will be translated to public IP
Step 3) Configure the NAT command line to translate the private addresses to a public IP
ip nat inside source list PRIVATE-NET interface fa0/1 overload
** If you are using your NAT config to reach Internet access, also remember to include a default route pointing to your ISP. The router where the NAT will be applied must know the subnets that you will translate.
This link could be useful:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-addr-consv.html
Please rate the comment if it was useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2017 09:11 AM
Hello
Just like to add you can utilize Domain-less NAT ( NVI NAT) which differs from Domain based nat regards order of operations and route lookups.
Domain Based - (route lookups performed either before of after nat translation - Subject to default nat order
interface x/x
ip nat inside/outside
Domain-less (NVI) Based - (route lookups performed before AND after nat translation, uses Nat Virtual Interface NVI)
interface x/x
ip nat enable
res
Paul
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2017 04:22 PM
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2017 05:19 PM
You are welcome
Have a good day!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2017 07:36 AM
Do u know ebooks to study ccna ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2017 08:13 AM
I recommend these books:
http://www.ciscopress.com/markets/detail.asp?st=44711
and
First steps for routing and LAN switching
http://www.ciscopress.com/search/index.asp?query=first+step
Theory and Practice is the key.
Hope it is useful.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-23-2017 01:37 AM
do u know web or forum to study ccna,ccnp , these book to much for me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-23-2017 04:40 AM
Hi my friend,
No worries, you could verify the topics of each certification and investigate them through internet one by one.
http://www.cisco.com/c/en/us/training-events/training-certifications/certifications/associate/ccna-routing-switching.html#~exam
Also you can create discussions through the Cisco Learning community:
https://learningnetwork.cisco.com/welcome
Other option is buy used books.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-23-2017 05:50 AM
ok ,very helpful :)
