NAT
Bunny12375
submit nat pt
open the packet tracer and configure a NAT statement to translate 209.165.100.1 to 10.10.10.254.
place statement on router 3.
NAT has inside local, inside global and outside local, outside global
Guys I need help
Hello
See attached revised file, with changes made.
Kind Regards
Paul
Hello
Kind Regards
Paul
Thanks, you explain pretty well than my professor did
rlopez23781290
Needing help with this problem as well. The file does not open. Any help would be appreciated on this problem.
if this is the same exact network, make sure you add the lines marked in bold to the ISP router:
Router#sh run
Building configuration...
Current configuration : 977 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 209.165.100.1 255.255.255.192
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
ip address 209.165.100.66 255.255.255.252
ip nat inside
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 192.168.0.0 0.0.255.255 area 0
network 209.165.100.0 0.0.0.255 area 0
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip flow-export version 9
access-list 1 permit 192.168.0.0 0.0.255.255
line con 0
line aux 0
line vty 0 4
login
end
