03-02-2006 09:37 AM - edited 03-03-2019 11:56 AM
Hi, I'm trying to provide internet access to several locations through a single point. These locations connect via point to point links that aggregate on a 3rd party cisco router then connect to my ethernet interface. I also have another point to point connection that I control that connects to the internet router via the same ethernet interface.
The remote location which I control has internet access through this router, and works as expected.
The local location also works as expected.
The remote locations which connect via the third party router act very funny. Machines from these locations can ping and ftp both to hostnames, and to IPs. However, web browsers merely say page cannot be displayed, and remote desktop conections fail.
Below is my current configuration. Any help or pointers would be greatly apreciated.
10.168.1.0/24 is the remote location I control. 192.168.1-3 are remote locations connected through the third party's IADs. My routers a 2801.
interface Multilink1
description outside
ip address 65.123.140.178 255.255.255.252
ip nat outside
ip virtual-reassembly
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface FastEthernet0/0
description inside
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 65.123.140.177
ip route 10.1.1.0 255.255.255.0 192.168.0.135
ip route 10.168.1.0 255.255.255.0 192.168.0.3
ip route 65.118.104.64 255.255.255.224 FastEthernet0/0
ip route 192.168.1.0 255.255.255.0 192.168.0.135
ip route 192.168.2.0 255.255.255.0 192.168.0.135
ip route 192.168.3.0 255.255.255.0 192.168.0.135
ip route 192.168.4.0 255.255.255.0 192.168.0.135
ip http server
no ip http secure-server
ip nat inside source list 1 interface Multilink1 overload
ip nat inside source static tcp 192.168.0.9 80 interface Multilink1 80
ip nat inside source static tcp 192.168.0.151 6253 interface Multilink1 6253
ip nat inside source static tcp 192.168.0.151 6252 interface Multilink1 6252
ip nat inside source static 192.168.0.2 interface Loopback1
ip nat inside source static tcp 192.168.0.151 6250 interface Multilink1 6250
ip nat inside source static tcp 192.168.0.151 6251 interface Multilink1 6251
ip nat inside source static 65.118.104.70 192.168.0.9
access-list 1 permit 65.118.104.70
access-list 1 permit 65.118.104.66
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 1 permit 10.168.1.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.252.255
03-02-2006 10:33 AM
since your network 10.168.1.0/24 is working fine, the problem might be with the 3rd party Cisco router your remote locations use to connect to the router whose connection you have posted. Do you have access to the (configuration of) that 3rd party router ?
Nethelper
03-02-2006 12:33 PM
I just got this config, but haven't been able to get one for the local 3rd party router, nor the redback between the two.
It's comforting to get a second opinion that it's probably not my router, as I'm baffled as to how it could be or where to get answers.
ip dhcp pool LaJamesPool1
network 192.168.1.0 255.255.255.0
dns-server 205.171.3.65 205.171.2.65
default-router 192.168.1.254
domain-name lajames.net
controller T1 1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
class-map match-any Voice
match dscp ef
policy-map FairVoip-75percent
class Voice
priority percent 75
class class-default
fair-queue
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no cdp enable
interface Serial1/0:0
description Qwest CID 1.HCFU.95534..NW
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay IETF
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial1/0:0.16 point-to-point
description SID 112941 - LaJames International College Davenport, IA
bandwidth 512
ip address 172.17.91.9 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
frame-relay interface-dlci 16 IETF
class voip-512k
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.91.10
map-class frame-relay voip-512k
frame-relay fragment 640
frame-relay cir 486400
frame-relay bc 4864
frame-relay be 0
frame-relay mincir 486400
service-policy output FairVoip-75percent
map-class frame-relay shape-512k
frame-relay bc 60800
frame-relay be 0
03-03-2006 10:41 AM
I got my answer, and everything was correct on my router.
After another couple of hours with the 3rd party on the phone and proving that complete end to end conversations worked, they retreated, escalated issues, and removed their QoS mechanism. Magically the issues have disappeared, and everything works.
