nbar,bit-rate
MARCELO MATURO
When I use nbar over subinterfaces fastethernet in a router 2801, it doesn´t work bi-rat and max-bit-rate on the second subinterce:
FastEthernet0/0.1
Input Output
Protocol 30sec Bit Rate (bps) 30sec Bit Rate (bps)
imap 34000 6000
smtp 11000 0
sna 0 0
ssh 0 0
http 0 0
proxy 0 0
eigrp 0 0
snmp 0 0
dns 0 0
ldap 0 0
unknown 0 0
Total 45000 6000
FastEthernet0/0.2
Input Output
imap 0 0
smtp 0 0
MS_T_SVR 0 0
sna 0 0
ldap 0 0
ssh 0 0
proxy 0 0
dns 0 0
http 0 0
eigrp 0 0
unknown 0 0
Total 0 0
vmoopeung
Level 5
Level 5
Check if you have configured "log-input". If yes, then remove it from the config because packet will not be process switched if we have that configured
