How to configure a built in switch for 1800 cisco router
pmpesha
I am pazzled how the switch connect to the router. Please assist.
spremkumar
Level 9
Level 9
you can refer this link in getting the required functionalities configured in your box..
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html#wp1046684
regds
wanwar
Level 4
Level 4
are you trying to use the 1800 router as a core switch to define vlans? it sounds like that is what you are talking about. please describe in greater detail what you're looking to do...
I am trying to establish a connection between the router and a built in switch. Do I need a physical connectin? I ssumed the connectin is intergrated. Thank you.
I got it! I am up and running. Thank you very much!
